46 FX carb
46 FX carb
Are there any carbs i can out on my Fx besides the stock OS one ? i was looking on tower and didn't see any compatible with it....thanks.
-Mike
-Mike
NY
46 FX carb
Conley products - used to be Perry carbs - lists a carb for the 46FX - I have used them and they are excellant replacements and cheaper than the OS carb
46 FX carb
Re: .46FX Carburettor
Originally posted by DarZeelon
Avistar,
The answer is NO.
OS is notorious for making irreplaceable carburettors.
Why would you want to change the carburettor on this engine?
If there is one thing that works right, lasts and does not limit power on this engine, it is the carburettor.
The USA is a free country, of-course, but I don't know a carburettor producing company, not even OS clone companies, which shares your aspiration and makes replacement carburettors for OS.
I believe this would put a lid on this thread.
Sincerely,
Avistar,
The answer is NO.
Sincerely,
Yes i understand what you are saying... but i was buying a new carb for one of my 46FXes and i was just wondering what my options were.....
NY
46FX Carb
Avistar23 - I stand corrected - they list the 1300S for the 46SF - which was the model b4 the FX - it may or may not fit - you would need to compare the the inside diameter of the engine throats - sorry if I misled you
46 FX carb
"OS is notorious for making irreplaceable carbs"??
I really don't think so!
There are plenty of other choices you can use for your 46FX (Magnum, Royal, ASP, etc - OS clones will likely fit) although outside of Perry carbs most other brands will likely not run as well as the original OS carb. My second choice for your 46 FX would be the carb off an OS 46SF - #4D. The 4D would be an excellent substitute and would provide you with a front needle with the same performance as the original carb on our 46FX.
OS Carbs
Avistar,
I stand corrected.
The current Magnum/ASP line has OS style side-screw carburettors.
I am not sure, though, whether they are of manufacturing quality, equivalent to that of the OS standard carburettors.
Thank you, Shemp.
Sincerely,
I stand corrected.
Thank you, Shemp.
Sincerely,
Re: 46FX Carb
46 FX carb
the 1300s is this:
http://www2.towerhobbies.com/cgi-bin...=++&search3=Go
This is the Perry (Varsane Products) #107 Large Carburetor for the
older O.S. .60 size 2-cycle(stroke) engines.
FEATURES: Idle mixture disk which regulates idle mixture. (very sensitive)
Durable plastic carburetor body.
Brass needle and barrel, metal throttle arm.
Rubber O-ring seal between the carburetor and engine crankcase.
INCLUDES: 1 carburetor with mounting screws to secure to the engine
and instructions.
SPECIFICATIONS: Throat outside diameter 13.46mm, Throat inside diameter 9.5mm
Venturi diameter 6.86mm .
COMMENTS:
AXY 6/8/94
this will fit my 46FX for sure ?
and instructions.
COMMENTS:
AXY 6/8/94
46 FX carb
well here is the os.. os its seems it will fit.
This is a #40B Carb by OS Max for the 40-46 FX and 50 SX series engines.
FEATURES: Cast and Machined Construction
Rotary Carb
INCLUDES: One Carb
One O-Ring
Two 3.5mm x 6mm carb screws, .6mm pitch
REQUIRES: Nothing
SPECS: Width: 40mm (1.57")
Height: 34.2 mm (1.35")
Carb throat diameter: 13.5mm (.54")
COMMENTS: Mixture control is adjusted through the middle of throttle arm.
NNA 5/5/02
ir/kh
Rotary Carb
INCLUDES: One Carb
One O-Ring
REQUIRES: Nothing
NNA 5/5/02
ir/kh
