saito rebuild?
#76
BC, CANADA
1 Post
RE: saito rebuild?
Hello; Hey cman. I want to help you. I didn't see the advice that you didn't get the "drift" of, so I won't comment onb that. Some poeple do appear to be a bit abrasive with their replies on this forum, son't be too concerned about it, or sensitive about it. I have never understood why anyone would reply just to belittle or critisize. Who knows, maybe he thinks he's helping.
Anyway, I don't understand the problem from reading all this.
#77
ID
RE: saito rebuild?
No body was condeming or critisize you Cman, I said you didn't get the drift and you didn't, on the smaller saitos you don't need to use a blade a pushrod thu the lifter hole pushed into the hole in the cam works great to hold the cam in place. But you can't use that method on the larger ones because of the lifters has to go in place there fore blocking of the pushrod hole. Thus you use the razor blade or exacto knife, from the side to hold the cam in place while setting it down in place. Sorry if you took it the wrong way. But I said nothing that should have upset you and bruised your ego.
#78
RE: saito rebuild?
I see this is an old subject, but I have a Saito 220 Seus and I can hear a clicking noise come from the cam cover area checked the tappets there fine, when look from the front the left side tappet clicks at the bottom cam area as you turn the eingine over.
Are the tappet push rod giudes at the bottom Pt N0 38 fixed or do they Floated and slide with the rod, help would be Appreciated. bristol UK
