Never Used a 1.20 Before, need some recommendations
My Feedback: (25)
I am putting an early version YS1.20 on a DP Ultimate. I've never used a 1.20 engine before, nor a YS. Just Saito's. The YS manual recommends Patternplane type props. I think they may carry to much pitch for biplane IMAC type flying. Could anyone with some YS1.20 experience tell me what fuel you were using and what prop. thanks.
My Feedback: (23)
6 pitch....so. 16/6 17/6
personally I prefer the wood 16/6 ma scimitar. it is not giving me max thrust because it is a tad small, but the spool up is excellent. plane is less than 9 lb so coaxing max thrust from the motor is not important. watch the over-reving though!
your plane will be 11-12lb so you will need all the thrust that engine can muster! use 17/6 apc if the engine will turn it comfortably, otherwise maybe 16/7 apc. the fz will turn the 17/6 apc but an older version may not have the poop to get the job done.
