Go Back  RCU Forums > Glow Engines, Gas Engines, Fuel & Mfg Support Forums > Glow Engines
 Help! Question on mac smoke system with os 70 4 stroke surpass engine >
Old 03-09-2009 | 10:12 AM
Default Help! Question on mac smoke system with os 70 4 stroke surpass engine
I just finished installing the mac smoke system (pumpless smoke system).
I used home-made smoke oil mix of 50% paraffin oil and 50% baby oil after reading so many nice comments about this mix!! supposed to get thick white smoke.
Unfortunately, for some reason, this mix seemed to be thick! In other words, when I tried to use silicon tubing the oil flows very slowly and I had to wait for almost 30 minutes to fill a 4 oz tank!!!!
I tested the system after starting the engine and I had ZERO smoke generated. I am suspecting that this oil is flowing very slowly in the silicon tubing and it probably needs much more pressure than the muffler pressure provided by the mac system.
I wonder if anyone experienced such problems with a similar pumpless smoke system.
I would appreciate any suggestion, comments, or corrections!
Thanks in advance!
Old 03-09-2009 | 10:46 AM
w8ye's Avatar
My Feedback: (16)
Default RE: Help! Question on mac smoke system with os 70 4 stroke surpass engine
I doubt that paraffin base oil is compatible with silicone tubing in the long run
Sounds as though you have a viscosity problem?
Old 03-09-2009 | 10:51 AM
Yes! Exactly right. There is a viscosity issue. The oil flows very slowly and requires a lot of pressure to flow.
I noticed there is a confusion about the name "paraffin". Some say in the UK it is a different name for kerosene. By paraffin, what I meant, is an oil that looks clear and very dense.
Old 03-09-2009 | 10:53 AM
w8ye's Avatar
My Feedback: (16)
The smoke oil I've smelled tends to have a hint of kerosene to it?
Any petroleum based oil is going to soften the silicone tubing eventually
Old 03-09-2009 | 10:55 AM
No! There is no kerosene in it!
Paraffin is NOT kerosene in my case. It is like vaseline
Old 03-09-2009 | 11:04 AM
To clarify what "paraffin" means in my case,
http://en.wikipedia.org/wiki/Paraffin
w8ye's Avatar
My Feedback: (16)
Paraffin, Vaseline, and baby oil are all petroleum oil based and will react with silicone. You must use a brown stopper in your tank and either Neoprene or Tygon tubing in your smoke system.
Try a small amount thinned with enough naphtha so it will freely flow? Be careful, the naphtha itself will burn like 65 octane gasoline
The SuperDri commercial smoke oil is thin
Old 03-09-2009 | 11:07 AM
I thought it is safe to put baby oil on one' face! How would it damage silicon tubing?!
Old 03-09-2009 | 11:26 AM
w8ye's Avatar
My Feedback: (16)
I've often wondered that fact about using Vaseline and baby oil on your skin is safe and it is made from crude oil. Doesn't make sense does it.
Look it up on Wikipedia or Google and see what you think?
