Carb fuel line
CA
Carb fuel line
What size line do ya use form the remote needle to the carb. I seems smaller than standard medium line and there seem to be no direct replacement available, for os AX46 and a couple tower .46's. I've been replacing it with medium line when they break but I seem to have trouble maintaining a needle setting. Is it just standard small fuel tubing?
My Feedback: (13)
RE: Carb fuel line
You can use the medium fuel tubing - no problem. If you're having trouble tuning the engine, I would look elsewhere. Look for bubbles in the line or other fuel delivery problem. I've never had a problem with medium fuel ine on the short connection between NV and carb.
