Piston ring types
Old 06-19-2003 | 09:01 PM
Default Piston ring types
What's the difference between a standard piston ring and a Dykes ring?
Old 06-19-2003 | 09:05 PM
AnthonyH's Avatar
My Feedback: (16)
Dykes ring is L shape regular ring is - shape. I think
Old 06-19-2003 | 09:22 PM
w8ye's Avatar
My Feedback: (16)
The "L" shape of the Dykes ring lets compression pressure get behind it for a better cylinder seal.
Normally with the engine not running and you just bring the prop through a compression stroke by hand, the engine will feel as though it has almost no compression.
Yet when the engine runs, it seals perfectly.
Jim
Old 06-19-2003 | 11:25 PM
Default Thanks
Now I understand why my motors feel as they have no compression. At least, I hope that's why!
Old 06-20-2003 | 12:00 AM
w8ye's Avatar
My Feedback: (16)
Not all engines have Dykes rings.
Most notably, the current engines that have Dykes rings, are the GMS 61, 75, & 120. There are others, but they are currently not in production or they are not very common.
Jim
Old 06-20-2003 | 12:36 AM
A normal piston ring is like what's used in a car or lawn mower engine. Roughly square in cross section and it relies on it's tension against the liner to make a good seal. Always fitted in a groove slightly below the top of the piston (obviously ).
A Dykes ring is L shaped and fits in a groove at the very top of the piston. This leaves part of the ring open above the piston so that any pressure in the cylinder can immediately get trapped behind the ring and force it out against the cylinder liner. The idea behind this is that the higher the pressure (as in combustion) the harder it gets pushed against the liner for a better seal. Turning them by hand doesn't generate much compression pressure and what there is can leak out fairly quickly. That's why they can appear to be worn out but in fact the ring hasn't had a chance to seal the way it's supposed to. Sometimes a starter is necessary to spin it over fast enough to reduce the leak down time.
Old 06-20-2003 | 01:44 AM
Much less frictional drag on L rings on the upstroke. Less friction, more power!
