Engines Quit
MI
I have two different engines, in two different planes and both die when I get to the top of vertical and chopping the trot. for doing a hammer head turn. One is a Saito 82a in an Edge 540, the other OS 91 Surpass in a Cub. I had a 4*60 with a ST 60 and it did Hammer heads great. I put the 91 from the Cub in it and now it Quits. Tanks are set up with three lines. Double Clunk, on fill and Carb. supply. I even completly Changed one tank, lines ect. Made knowdifference. In every other aspect both engines run great.
Suggestions?
Suggestions?
TX
How long (time) is your run up to the vertical? If you take a long time, you will be plagued with the problem. Make sure your pressure line is on the muffler and does not have a split or hole in it. Fuel has got to be lifted from the bottom of the tank all the way to the carb. That is some distance of achieve.</p>
Cheers,</p>
Chip</p>
MI
<span style="font-family: Comic Sans MS"><span style="font-size: medium"><span style="color: #ff00ff"><span style="font-size: small">Thanks guys, will give it a try on Sunday.
Vertical run, can't be more than 3/4 seconds. (Guessing)
Rich</span></span></span></span></p>
ORIGINAL: RICMOD5634
