Problems with Enya 80 4C
Old 06-25-2003 | 01:40 PM
Default Problems with Enya 80 4C
Hi all!
I own a Enya 80 4C. I runned it in when it was new 10 years ago. It then sat on the shelf until last year. I then started use it in a Spitfire. Now it probably have about 8 hours of running time.
The problem is that it now has lost some compression and is spiting out a lot of brown oil thru the breathing nipple in the crank case. I have adjusted the valve clearance according to the operation instruction (0.05-0.1 mm). The engine is still running but maybe lost a little power.
What can be the cause to the problem?
Regards
Krister Bergenfeldt
Stockholm, Sweden
Old 06-25-2003 | 02:07 PM
mscic-RCU's Avatar
Probably the piston ring is stuck due to all the varnish in it. It will probably clear up if you run the engine. Worst case, you will have to replace the ring.
Old 06-26-2003 | 08:35 PM
Hej!
Det bruna som kommer ut ur motorn är rost blandat med olja!
Rosten kommer från kullagern och allt annat som är gjort av stål i motorn och som legat och rostat under alla år.
Vad du måste byta i motorn är kullagren ...och kanske kolvringen..du måset iallafall kolla att inte kolvringen sitter fast i kolven (gammal ricinolja kan åstadkomma detta).
I vilket fall som helst måset du byta kullager!
Hälsningar!
Jan K
Väsby MF
The brown stuff that comes from the engine is rust mixed with oil.
The rust comes from the ballbearings and all the other steel components in the engine.
You have to change the ballbearings....probably check that the pistonring is not stuck in the grove in the piston (old castor oil can do such things)-
At least you have to get new ballbearings!
