YS 45 engine help
Old 07-29-2009 | 05:14 AM
Default YS 45 engine help
Started breaking in the engine last night, this is my first pumped 2stroker. Had a problem It just floods!!! Turning the low speed didn't seem to help. I replaced the diapram will try it when I get home from work. Also IT MAKES ALOT OF PRESSURE!!! should I be using some type of regulator?? Its a beautiful engine I plan on mounting it on a Laser Arrow delta I am using a MACS 1250 pipe and the final prop is goingto be a 9x9 APC
Old 07-29-2009 | 11:54 AM
MetallicaJunkie's Avatar
Default RE: YS 45 engine help
i had the same problem with mine, i had to turn in the diaphragm regulator valve screw a couple of turns in to keep it from loading up on idle ... You are using a check valve right?
Old 07-29-2009 | 12:50 PM
Yes sir Iam using the check valve. what prop, pipe, and header length did you run?
Old 07-29-2009 | 12:59 PM
I used the macs tunes pipe 1140....10x7 mas prop... from the glow plug to the apex of the tuned pipe was 12 inches
Old 07-29-2009 | 01:18 PM
Thank you what kinda of RPM did it turn and with what fuel+glow plug
Old 07-29-2009 | 04:06 PM
I have two NIB 45s that I have not run but I have run a couple of the YS 61s(the 45's larger cousin). They do develop a good bit of tank pressure. You will easily see the tank swell a bit under this pressure and when you are done running the engine and open the vent line to relieve the pressure, there is a noticeable amount of air that rushes out. This is normal.
Old 07-29-2009 | 04:16 PM
about 14500 with 15% when i get a header for it im going to run a 10x6 to get more rpm
