OS 7D Carb
My Feedback: (79)
Whichever one adjusts to your liking. The pointy one will be much more sensitive while adjusting. They probaly supplied two, since the 1.08 used to also come with a venturi sleeve to allow low RPM use with excellent fuel draw, along with high rpm use and a large venturi.
ok i dont have the brass insert....i modified it to fit on a rossi....i since i want it for high rpm i guess its ok that i dont have the venturi insert... What neelde would you use?
edit* thanks for the answer....ill bench it this evening and see which needle works best
