os .40 carb needed
Old 09-06-2009 | 07:22 PM
My Feedback: (12)
Default os .40 carb needed
I was flying tonight and my throttle went wide open. A minute later I heard something hit the prop and then I was dead stick. When I landed I had lost the carb off the engine. If anyone has one Please contact me at [email protected]
Jeff
Old 09-06-2009 | 07:26 PM
My Feedback: (90)
Default RE: os .40 carb needed
OS carbs come in a lot of flavors. You need to say what model OS 40 you have. h,fsr,fs,fx, ax,la etc.
otherwise you might get something that you don't need.
Dennis
Old 09-06-2009 | 07:32 PM
w8ye's Avatar
My Feedback: (16)
Did it look like this?<br type="_moz"/>
Old 09-06-2009 | 10:04 PM
My Feedback: (12)
I am pretty sure that it is a fs model. I think I found the carb on tower hobbies site but it goes for $30. I thought that maybe someone had one laying around that would sell for a better deal.
Jeff
Old 09-07-2009 | 06:14 PM
jeffie8696's Avatar
what is the stem diameter?
Old 09-07-2009 | 06:41 PM
My Feedback: (12)
Here is link to what I believe to be the carb on tower's web site.
http://www3.towerhobbies.com/cgi-bin...?&I=LXCA10&P=7
Anyone have one of these they want to sell?
Jeff
Old 09-07-2009 | 06:49 PM
w8ye's Avatar
My Feedback: (16)
They must be dumping them for last year they wanted like $60 for the carb,
They want more than $30 for one of the major parts of the carb.
This is a lot of carb for a OS 40FX. I doubt you will get the engine to run satisfactory. The carb is made for Heli's. The throttle ability is just not there for a 40 or 46FX engine.
Old 09-07-2009 | 09:24 PM
My Feedback: (12)
I didnt notice that it said that it had an H behind the part #. I dont even see one listed on towers site under os carburator. Looks as if I might have to find a used engine just to get a carb.
Jeff
Old 09-09-2009 | 12:38 PM
My Feedback: (90)
ORIGINAL: jjoos99
Jeff
Post a picture of your engine, that will simplify things a lot.
dennis
Old 09-09-2009 | 03:14 PM
jeffie8696's Avatar
Measure the stem diameter and I may be able to get you a good carb.
Old 09-09-2009 | 09:07 PM
My Feedback: (12)
This engine is a .40 sf model. The above listed link is for a heli carb that will fit my motor. the listing shows it to have an outside diameter of 13.5mm.
thanks
Jeff
Old 09-09-2009 | 11:08 PM
jeffie8696's Avatar
OKIwill check to see what the diameter of mine are.
Old 09-11-2009 | 10:55 PM
The OS 40 SF came with the 4D carb.
jeffie8696's Avatar
Just checked and I see mine has a diameter of 13MM so it should work but you would have to drill and tap the bolt holes.
