os 70 ultimate help
I have got an os 70 ultimate that smokes a lot when you pull the throttle to idle and make a left turn and decent i was thincking it could be the mixture but i wanted advice first because the engine transitions smoothley.
Smoking at low throttle/high manifold vacuum is quite common with model four-strokes. I notice mine all do that to a greater or lesser degree - especially OS Surpasses with their oil recycling crankcase venting mechanism.
If the Ultimate is running well otherwise, I'd just leave it and enjoy the smoke show.
