New AVIASTAR 46 thread
#76
ORIGINAL: jeffie8696
One of the most basic ways to change the torque curve is by the ratio of boreto stroke. Large bore short stroke engnes move the power tothe higher rpms. Long stroke engines have more mechanical advantage over the crankshaft ad thus more torque. I will look into the dimensions.
Large bore short stroke engines are good at reducing piston speed, I think that is a key claim to fame with regards their use in high rpm applications. Certainly in F1 (auto) engines where they are at the practical limit of piston speed all the time, whereas surprisingly with our small high rpm engines we rarely get anywhere near as close.
I'm not actually arguing you about the point, but I am curious what other advantage longer stroke and smaller bore actually offer (but better put that on another thread!). Other, that is, when it is incrementally changed by the manufacturer for one reason or another and they can advertise the new engine as "long stroke" or "short stroke" compared to the last version, as if that is the only change that matters.
MJD
#77
ORIGINAL: MartyH
This has been an experiment for me. These things are just air pumps and a carburator. I have read the ''thing this is trash'',''what a piece of cr%p'' posts about the Mecoa 46, the Megatech 46, and this engine, the Aviastar 46. I have 3 engines in 2 versions of the Mecoa 46, I have a used Megatech 46 and now an Aviastar 46. All 5 of them setup and run like any other typical 46 2 stroke. glow. Can I really be this lucky?
Anyway, I'm sorry anyone is having trouble with their engine and not enjoying the hobby. I'm not a distributor for this engine, I'm not telling anyone to go buy one. I'm just saying that I'm a fellow modeler that doesn't share your opinion that this engine is trouble. It's a nice engine at any price. It's an amazing engine at $49.99 from Sig Manufacturing!
So many times in this hobby, someone gets a good deal on something and it works, so they wax eloquent about the product - naturally. But because of the inconstencies with many of these engines, there is a crowd of skeptics out there, and for good reason.
Reporting on your observations and fixes or techniques is a good thing and useful to anyone considering or owning the same engine - no question there. But I would not be surprised to find out that some of the nay-sayers have had legitimate poor experiences with the engine. IMHO, as a sport engine, making it too tight for the average low-engine time sport modeller to deal with is bad design or manufacturing as the case may be, and there is no excuse for that with all the good examples on the market and the decades of knowledge base on the subject. $49.99 sport engines are not supposed to require cylinder heating and super-careful break-in to use. That's for the smaller percentage of modellers with the knowledge or willingness to fiddle.
MJD
#78
My Feedback: (16)
IN
I'm up to a gallon and a half through the engine now. I changed the prop from 10 X 7 to 10 X 8 apc and it proved to be too much. I do not find this engine to be any different from any other typical sport .46 in terms of torque. Its a nice, typical .46 2 stroke glow engine.
#79
On one particular point I have to whole heartedly agree. The less expensive engines require the user to be more informed and spend more time getting it right than do the more expensive types so yes I do recommend the beginner buy the highest quality engine they can possibly afford to help eliminate any obstacles to their training.
However if you have a sincere passion for the sport and need to save every penny (so you can afford that new plane or whatever) then the less expensive engines have a place. I could buy a brand new OS 46AX for $130.00 or I could buy a new Aviastar .46 engine ,,,and a plane to boot.
I may need to use more of my engine savvy to get it to run properly in comparison to the OS engine but that for me is half the fun.
#80
Jeesh, give it a rest... what happened to;
MartyH;
Well, I guess this is my last post on this subject. My Aviastar 46 engine is perfect.
We get it - you were one of the lucky ones who got a $50 engine that you didn't have to fiddle with to overcome problems that both the manufacturer and distributor admit to.
Hurray for you.
#81
My Feedback: (16)
IN
ProBroJoe, I posted more in this thread because there was more to share. This isnt gloating or bragging nor is it necessaarily even good news. Jeff had me hoping I might be able to run a 10 X 8 since he found that he seemed to be able to swing larger than average props or more pitch than one typically could with a .46. I was reporting that I didnt find that to be the case for me. Since you are not flying one of these engines and seem to resent good news about this engine, why not just stop reading this thread?
#82
Since you are not flying one of these engines....
#83
My Feedback: (16)
IN
Nope, I don't remember you ever saying you had one flying. Why so down on the engine then? As for the 10 X 8, that hasn't worked out on my Bobcat but it's nearly 8# with fuel so I assume its that I need the 10 X 7 to plow that big airframe through the sky. They might look like jets but they are draggy airframes.
#84
As for the 10 X 8, that hasn't worked out on my Bobcat but it's nearly 8#.....
#85
My Feedback: (16)
IN
I found your PM. You said....
Yes I am down on this engine, and yes, I currently own one. I've had it since May '08, replaced the carb with one from a Super Tigre, and it's been OK, but still behaves in such a way that it doesn't give a warm and fuzzy feeling when I fly it.
If you don't like it, why not dump it and move on? Life is short and you obviously are not enjoying the hobby with this $50 engine. As for denouncing other people's problems or opinions, I have offered possible explanations for some people's trouble and have passed along my first hand experience. I went on to suggest that if there were problems with this engine, I dont think there are now and that if someone buys one from Sig after the date I bought mine and has trouble that I would encourage them to send it to me. I'm sorry this thread sits so wrong with you. I say again, why not just stop reading it?
#87
I went on to suggest that if there were problems with this engine...
#88
My Feedback: (16)
IN
Ok, I quit ProBroJoe. I've been just trying to help guys in a positive manner with this engine by sharing my real world experience. This is about the greatest hobby I can think of! I apologize to you for not having problems with the engine. Your negativity wins. I'll spend my time more productively somewhere else.
#92
Is that 15% Helimix fuel all synthetic? If so your ABC type engine isn't getting much scuff protection. (zero clearance at the top of the stroke) A small amount of castor in the mix would be a good insurance policy for longevity. Just my opinion though....
Thanks for the great updates,
Ernie
Ernie
#93
Received some great news late last night. Alvin So of Aviatronics is out of the hospital and working at the plant on a limited basis.
Apparetly he has been in and out of the hospital over the last 6 months and at one time spent 22 straight days there.
He has contacted me and we are going to straighten out any issues we can with his engines to ensure they become the premiere model airplane engines that Alvin wants them to be.
Iam wondering if anyone thinks (besides me) that a ringed version of his .46 and .53 would be a good idea? If so Iwill see if we can get it implemented.
#94
I am wondering if anyone thinks (besides me) that a ringed version of his .46 and .53 would be a good idea? If so I will see if we can get it implemented.
Sig listed the Aviastar 1.20 at $179.99; I thought that was a pretty attractive engine at that price. Sig might be inclined to offer any smaller Aviastar engines that aren't currently being imported to North America. An Aviastar .25 might be fun to try, for example. I don't know if Aviatronics manufacturers any smaller engines, it's just a thought.
http://www.aviatronics.com/review.htm
#95
My Feedback: (20)
TX
One of my trips to the hobby shop many months ago got me looking at the Avia 46's he had (nothing catches your eye like a 49.99 price tag). I didnt pull the trigger that day because I knew nothing about them. Once I got home I got on RCU and started searching and found several posts on the Avia's and noticed the Carb SNAFU's that went along with them, I think it had something to do with the 46's carb spraybar (it was the wrong one) and Sig was repairing the effected units, but that was a good while back from when I was reading it. On my next trip in I couldn't help myself and picked one up, I knew I was taking a chance that it may have problems but I really enjoy tinkering with engines (have been working on/rebuilding ATV and Dirtbike engines since I was around 14). I put the engine on a high wing trainer replacing the Super Tigre 45 that was on it. Sorry but that Super Tigre muffler is absolutely the ugliest piece of engineering I've seen in a while. Super Tigre went back on the Sig 4* it was transplanted from. Which was fine because the 4* balanced perfectly with the Tigre but left the trainer way nose heavy. The Avia is a little lighter and the muffler isn't fugly. Bolted the Avia in the trainer and went to break it in. Engine was tight but it still started very easily. Ran 4 or 5 tanks through it at around 4000rpm with a few short higher RPM blips, then started leaning it a little and increasing the RPMs. This is where I expected my problems to begin but they never did. The engine ran like a screamin demon. The throttle response was great, the transition was great and it would idle for as long as I asked it to without loading up and petering out. I think the transition on the Avia is cleaner than the Super Tigre, the Avia will also idle longer without loading up. Power wise I'd say they are both dead even but I like the Avia better.
Next time I need another .40 sized engine I'm buying another Avia.
