Help. Can't start engine
I am trying to start a thunder tiger .21 pro in my schumacher fusion, and if i can get it started it will just die really quickly. I have been able to get it started but when i take the igniter out, it dies again, what should i do. I am still trying to break it in. I got it started before for an idle, but now it won't start
Check the glow plug and put in a replacement if you have one. Check all the fuel lines and replace them if you have extra. Make sure the tank is tight and make sure the needle valve is out at least 2.5 turns to start with...Read all your manuals.
Banned
It sounds like you need a new glow plug if it dies as soon as you take the glow battery off. It is not uncommon for it to eat a few plugs getting broke in. Get the engine instructions for that motor and see what it said about break in . Make sure you have the correc t fuel and get someone to help you through the break in process.
yea i will change the glow plug out, but i couldn't find any break in instructions in the manual it just says run rich for 2-3 tanks, which is pretty vague.
I found this site, but I just wanted to make sure this would be a good way to break in the engine, so if ya'll could look at if for me it would really be appreciated!
http://www.geocities.com/rcntrucks/nitro_engines.htm
