OS .61 sf specs?
OS .61 sf specs?
Guys, my googling has been unsuccessful in finding the specs on the old OS .61 sf engine. Looking specifically for the weight of the engine & muffler as I believe this was the long stoke engine of the day? I trying to choose a comparable weight engine (bigger bore obviously) for my Ultra Sport 60 kit build so I'm not way too nose heavy.
Thanks!
Thanks!
HI
RE: OS .61 sf specs?
contact bax at hobby services...he should be able to help you...btw, i have a nib os61sf-p...supposed to go in a venture60 kit, but never got around to building it...
http://www.rcuniverse.com/forum/m_2037866/tm.htm
HI i run a 91 fx in my 60 size ultrasportthe 91 is a little less weight than most 61 engines as it is a bored out 61 casethe 91 is known for the rear needle valve to leak-so look out for that-if you go with a 61-i have two outstandingpowerhouse OS engines for sale -a 61 sf and a 61 fsr (the 7d carb )-both are trulyjust past there break inif interested call 352-560-7359TONY
my ultrasport has 1/2 oz of lead in the tailso balance is no problemflying mine 8-10 yearsbuilt the kit then ENJOY TONY
