ASP .91 Help Wanted
Help, Help....my muffler flange broke off (in flight) and I lost the muffler. I need another ASP .91 muffler or another muffler that will fit the ASP .91 case. Can anyone help??[:o]
[/b]
Russ V.][/b]
(406) 781-7233
[/b]Thanks
Russ V.][/b]
(406) 781-7233
I think the ASP .61 and .75 use the same muffler as the .91. Also the ASP is basically a clone of the OS, so the OS mufflers should fit. But to be sure, measure the distance between the holes and compare. Justengines in the UK sell the ASP and likely can provide you with an ASP replacement.
I think that Magnum muffler fit as well. The 70 and 91 fit each other.
http://www.hobbypeople.net/gallery/284083.asp
http://www.hobbypeople.net/gallery/280107.asp
http://www.hobbypeople.net/gallery/284084.asp
Dru.
Dru.
My Feedback: (16)
ORIGINAL: R Verbael
[/b]
Russ V.][/b]
(406) 781-7233
[/b]Thanks
Russ V.][/b]
(406) 781-7233
If you have a two stroke is it a XL or XLS 91 ??
First, thanx for the quick response. The engine is a 2-stroke glow engine. Do not know which series, etc. it is.
My lost muffler engine has the bolt holes spread apart 34.5 mm and I have a second ASP .91 that has a muffler mounting bolt hole measurement of 43 mm. Not even close.
If anyone has a muffler with a mounting lug hole spread of 34.5 mm, I'd sure like to buy it.
Thanks.
Russ V.
Thanks.
Russ V.
My Feedback: (14)
ORIGINAL: w8ye
The 43 mm one is the one that is like a OS. This is the current (S) version of the ASP 91 two stroke
The other one is pretty old
Jim, I bought a couple of ASP 1.08 two-strokes from Hobbycity a short while back for $69.95 each. Is this an OS clone? The original 1.08 RedHead was not, although it was a great engine. Just wondering if you knew anything about these ASP 1.08 engines? TIA
Ed Cregger
