Replacement gaskets
Old 01-03-2010 | 04:12 PM
ceecrb1's Avatar
Default Replacement gaskets
I'm having problems finding replacement gaskets to go between the motor and the exhaust pipe...
Would I be able to use a high temp silicon???
Old 01-03-2010 | 04:35 PM
BarracudaHockey's Avatar
Default RE: Replacement gaskets
You can use red RTV, put a VERY THIN smear on it, let it set up a little and bolt it up.
I don't use gaskets.
There is a guy advertizing in March 2010 issue of MAN laser cut engine/muffler gaskets. His web site is:
http://icbimproducts.com/gaskets/
Bruce
Old 01-03-2010 | 11:40 PM
faulknej's Avatar
My Feedback: (9)
The gasket is not necessary. A lot of old fliers at my club tell me they make the muffler fall off. Istopped using them and haven't had a muffler come loose since.
Old 01-03-2010 | 11:52 PM
For me it was a waste of time. Flown many years without them and not a problem. Seems when I do try one, it lasts few flights then the muffler is loose. I gave up on the gaskets a long time ago.
Dru.
Old 01-04-2010 | 02:36 AM
Sounds like I'm in a minority. I use them and make my own out of the thinnest automotive gasket paper I can get my hands on.
If you tighten the silencer bolts up while the engine is hot after the first couple of flights ... never a problem with screws backing out in my experience.
Old 01-04-2010 | 08:33 AM
Mr67Stang's Avatar
If the mating surfaces are machine finished a gasket should not be neccissary.
Old 01-04-2010 | 08:50 PM
On the magnums/asp/sc 2 stroke engines, the mating surfaces are not machined so I would use a thin layer of RTV silicone, as I did on my Magnum 46 xls.
