saito timing?
Old 03-02-2010 | 08:28 PM
Default saito timing?
Hi,
Any body know how to set the correct timing for the cams on a saito 115? As I`ve had to replace the bearing and then realized I`m not quite sure how this bit go`s back together.
Thanks.
Old 03-02-2010 | 08:31 PM
ThumbSkull's Avatar
My Feedback: (57)
Default RE: saito timing?
Dot on the cam straight down at 6 o'clock. Crank at TDC (12 o'clock, piston all the way to the top).
Old 03-02-2010 | 08:37 PM
w8ye's Avatar
My Feedback: (16)
Hold the cam still with an exacto blade jammed into the gear teeth at the gasket surface of the cam cover while you insert it onto the crankcase
Hi,
Thanks for the quick reply, Is there any tricks to make sure I get it right first time? and is this the same for all saito single cylinder engines?
Thanks.
Old 03-02-2010 | 08:42 PM
Hobbsy's Avatar
My Feedback: (102)
Beefer, run the crank around 360 degrees from where you set the timing and both vales should be open a small and same amount.
w8ye's Avatar
My Feedback: (16)
Double check your timing after assembly by turning the crankshaft one full turn form top dead center on the compression stroke.
At top dead center you will be on the overlap stroke. One valve will be almost closed and one will be almost open. Both valves should be open the same amount if the timing is correct.
All the singles are the same
Old 03-02-2010 | 08:48 PM
Hi,
Thanks for the info
