YS 110 Information Please...
Old 07-16-2003 | 09:26 PM
My Feedback: (18)
Default YS 110 Information Please...
I have a YS 110 coming and would sure appreciate any information anyone could send my way pertaining to this engine. It is going on a Quest 3D could anyone give advise as to a prop etc...Thanks in advance for any help anyone can provide...
Old 07-17-2003 | 01:38 AM
Richard L.'s Avatar
My Feedback: (24)
Break in: 15x8
Flying: 15x8 - 15x10, 16x6 - 16x7
Old 07-17-2003 | 01:41 PM
MarkNovack's Avatar
Default On prop size.
Final prop selction depends a little on flying application and nitro. With Coolpower 30%, 16-8 puts the RPMs in the 9200-9400 range, perfect for the motor. For 20% nitro, smaller props (15-8,16-6,7 will work well). Look for keeping it in the 9200-9600 range. On 30%, we were turning 10,300 on the 15-8.
For pattern, a 15-10 is awesome. I agree with the break-in prop as a 15-8. Also, put this one on the bench for a few tanks full. I recommend a gallon on the bench. Many people running this motor are experiencing deadsticks due to overheating. Once the piston and ring seat in nicely, the motor will reach complete reliability and maintain nice even temperatures.
Mark
Old 07-17-2003 | 07:53 PM
My Feedback: (18)
Mark,
I plan on using my Coolpower 30% heli fuel for this engine and fly mostly pattern with it. I am not too concerned with dead stick situations and am wondering that it might run cooler during break-in if it is moving through the air after a few tanks on the ground? What do you think? Where I fly the dead stick landing are not much of a problem....Thanks......
Old 10-03-2003 | 11:46 PM
Default RE: YS 110 Information Please...
Heat is good during break in. The alloy parts in the motor need to be heat cycled to relieve stress and heat is needed so the motor will reach its operating tolerances. Modern motors are designed so clearances are right at a certain operating temperature.
If you run rich (so you have to keep glow heat on to keep it running) on the bench it will keep cool enough to safely run 10 minute intervals. I run 6 - 10 minute break in runs then I fly rich (700rpm below peak) through the rest of the gallon.
Old 10-04-2003 | 10:26 PM
Synthetic,
I have the same combo Quest/YS110. When I bought my 110 from Central Hobbies they recommended a 14x11 for break in. Only 1/2 gallon through it but turns 9500 rich on 20/20. Good speed but a little more thrust would be nice. I ordered a 15x8 and a 15/10 to try. You will love that engine. Plenty of power for the Quest.
Old 12-05-2003 | 02:10 AM
Default RE: On prop size.
ORIGINAL: MarkNovack
Mark
Maybe it is not very approprite to compare but a Zenoah G26 can turn a 16x8 at about 9000. If YS 100 can turn this 9200-9400 then it has to be really awesome.
Generally OS and other 140 size 2 cycle manufacturers ( Webra ) advertise their two strokes by saying these do not have the complexity and maintenance of 4 strokers. I would like to ask YS users that is there something has to be done extra to maintain YS engines? The most compex thing I do with my 4 strokes are adjusting the valves in every 50 - 100 flights, MAYBE a bearing change every year. Isn't it the same with YS ?
Old 12-05-2003 | 10:32 AM
Richard L.'s Avatar
My Feedback: (24)
There is very little that has to be done extra to maintain a YS. Checking the valve clearance and replacing the fuel filters are good ideas. You do not need to change the bearing every year.
Old 12-16-2003 | 12:58 AM
Wolfpack's Avatar
I just bought this engine and I do not have it yet. I was searching to find recommended props. DOes anyone know why tower hobbies has the recommended props as follows:
Recommended Props: 13x11, 13x13, 13.5x10, 14x10, 14x12
I notice no one here is using any of these? please help...
Old 12-16-2003 | 01:31 AM
Richard L.'s Avatar
My Feedback: (24)
Those props will be fine if you are going for all out speed and don't care about torque and good vertical performance. If you want the best of both worlds, then stick with a 15x8 or a 16x7.
Old 12-16-2003 | 02:02 AM
Wolfpack's Avatar
how fast do you think at 8lb plane will go with a 15x8 or a 16x7. ?
Old 12-16-2003 | 06:09 AM
Sprink's Avatar
ORIGINAL: Wolfpack
I think they based that on the old 91.
Old 12-16-2003 | 10:32 AM
Richard L.'s Avatar
My Feedback: (24)
Pretty fast. My 8.2 lbs WM Spit is extremely quick with a 15x8. You will lose some speed with a 16x7. If you want even more speed, then use a 14x10.
Old 12-18-2003 | 01:13 AM
Wolfpack's Avatar
does the engien come with the check valves required? IF not what check valves are people using?
Old 12-18-2003 | 01:23 AM
Richard L.'s Avatar
My Feedback: (24)
A factory check valve should come with the engine. Double check your box. Use only YS check valve for this engine, which can be purchased from Central Hobbies.
Old 12-21-2003 | 02:30 PM
The prop sizes Tower Hobbies quote are the ones in the YS operating manual that comes with the engine. No check valve is included in the engine box, only a filter.
I am putting the 1.10 in my TF P40, will the 15x8 prop be ok, or does anyone else recommend another size?
Old 12-21-2003 | 02:57 PM
Richard L.'s Avatar
My Feedback: (24)
If your filter happens to look like this:
then it is a check valve. I have bought four YS 110's, and all came with check valve and no fuel filter.
Old 12-21-2003 | 03:07 PM
Richard, just went and looked in the box and opened the plastic bag the valve was in, yes you are right it is a check valve not a filter, Now why cannt YS get their manual correct in this day and age?, it says in the parts supplied in box, 1 filter. never mind, and I went and brought another check valve.
What size prop would you erecommend for the TF P40? It will not be installed for another couple of months but will bench run it when it gets warm enough to stick my head out of the house.
Any particular recommendations on fuel type? 20 - 30% nitro fuel is pretty impossible to get over here and costs an absolute fortune , about £30 a gallon in my model shop if they have it in, I will shop around and try to find something soon .
Thanks for the help.
Old 12-21-2003 | 03:52 PM
Richard L.'s Avatar
My Feedback: (24)
ORIGINAL: djay
A good general purpose prop to use is a 15x8 or a 15.5x8. If you want to turn your P40 into a pylon racer, then use a 14x10. If you want more torque at the expense of a little speed, then use a 16x7. It all depends on the type of flying that you will be doing.
Old 12-21-2003 | 04:26 PM
Sprink's Avatar
ORIGINAL: djay
You need to shop around a bit more. Should not be a problem for getting 20% nitro for less than £25. Weston pro synth is about £23 from memory. And probuild can sell you fuel as well. Also try the dedicated Heli model shops as they tend to have the higher nitro stuff available.
