OS 91 Surpass
Old 05-28-2010 | 08:10 PM
Guitarman52's Avatar
Default OS 91 Surpass
I love this engine but I cannot keep the muffler on !!!! About 2 flights is all I get and then it is loose. I have tried everything, including blue thread locker, red thread locker, JB Weld, nothing works. I contacted Tower Hobbies where I purchased it from and they told me that I probably tightened to tight to start with. They said if you do that it will work loose and nothing will keep it on. They said to just snug the nut up against the muffler. I am talking about where the muffler connects to the header, not the engine. I hate to pay $63 dollars for a new muffler... I thought Tower would warrant it, but they would not. I have bought a ton of stuff off of them, but I guess that doesn't matter. It seems like Horizon has much better service after the sale.
Old 05-28-2010 | 08:13 PM
w8ye's Avatar
My Feedback: (16)
Default RE: OS 91 Surpass
I have a couple of these engines since they first came out. I've never had trouble with the muffler. I have four mufflers.
Old 05-28-2010 | 08:16 PM
Why do you have 4 mufflers for 2 engines?
Old 05-28-2010 | 08:28 PM
w8ye's Avatar
My Feedback: (16)
People over the years gave me mufflers. A couple are from Surpass I's and one is a prototype of another design that works very well on the Surpass II. Then I have the two original Surpass II mufflers. The Surpass I mufflers are a little smaller and lighter.
Old 05-28-2010 | 09:58 PM
yellerchamp's Avatar
My Feedback: (42)
use the magnum muffler its cheaper and works fine. Also if you still have trouble try teflon tape, the red locktite should work okay.....
Old 05-28-2010 | 10:02 PM
MinnFlyer's Avatar
First, balance your prop. That alone might do the trick.
If it doesn't, use the old safety wire trick. Get some thin copper or steel wire, wrap it around the muffler at the pressure nipple with one wrap around the nipple. Now twist the two ends of the wire and wrap the twisted section once around the header opposite the way the muffler screws off. Finally, tie it off at the head. Now it can't unscrew without tightening the wire.
Do a Google image search for Safety Wire for pics
Old 05-28-2010 | 10:09 PM
My Feedback: (264)
I would suggest you use alcohol and a old toothbrush to clean the threads on the header and inside the muffler and jamnut threads, get all the old oil, varnish and metal particles out of those threads. Put everythind back together and snug down the jamnut. Should be good to go.
The prop balancing idea is a good one also, always balance your props.
Old 05-28-2010 | 10:45 PM
w8ye's Avatar
My Feedback: (16)
I bought a Saito 62 from a guy on here that he sold because it was breaking muffler manifolds
It came with a new manifold. I'm using it for the second year and have never even adjusted the needle valve let alone have muffler trouble.
He sent an aluminum spinner and adapter nut along with it, The 2 1/4" spinner had been forced over a prop without being cut out. I don't know if that was the problem or not?
Old 05-29-2010 | 09:57 AM
blw's Avatar
blw
The teflon tape is a good way to go for the moment. Balance your prop(s) with a good balancer, not the finger balancer.
Use something like Dawn's Power Dissolver to clean the threads before wrapping with the teflon tape.
Old 06-01-2010 | 12:23 PM
I have tried everything... nothing is working. I ordered a new muffler and header. If it comes loose this time I am sending the whole engine back to hobby services.
Old 06-01-2010 | 12:33 PM
w8ye's Avatar
My Feedback: (16)
I've had 9 of these type engines and the designs that came before them and some for 20 years and have never had a problem with the muffler coming loose.
Old 06-01-2010 | 12:49 PM
My Feedback: (14)
Let me guess, you have been running the engine on a soft mount - right?
Ed Cregger
Old 06-01-2010 | 03:16 PM
ORIGINAL: w8ye
I guess I am the born loser, although we have 2 other guys in our club that have had the same problem.
Old 06-01-2010 | 03:36 PM
w8ye's Avatar
My Feedback: (16)
To tighten them when they are hot from running sometimes helps
Old 06-01-2010 | 11:00 PM
Iflyglow's Avatar
My Feedback: (79)
Teflon tape and really snug it up when it is hot, is the secret that I have used for years. I nolonger ever see problems at our field after I told my buddies about the idea too.
