EVO engine front needle conversion
Old 08-02-2010 | 08:55 PM
AraTidwell's Avatar
Default EVO engine front needle conversion
Is a front needle conversion possible on EVO engines or are you stuck with remote needle valves?
thanks,
ara
Old 08-02-2010 | 09:21 PM
w8ye's Avatar
My Feedback: (16)
Default RE: EVO engine front needle conversion
Which Evo you have
Old 08-02-2010 | 09:24 PM
w8ye's Avatar
My Feedback: (16)
All the current ones - you can just put the needle assembly into the side of the carb where the black hex nut is?
Old 08-02-2010 | 09:28 PM
w8ye's Avatar
My Feedback: (16)
Remove the black hex nut from the side of the carb
http://www.horizonhobby.com/Products...dID=EVO100E46C
And put this piece from the rear needle valve in its place
http://www.horizonhobby.com/Products...odID=EVO100830
Old 08-02-2010 | 10:24 PM
proptop's Avatar
My Feedback: (8)
ORIGINAL: AraTidwell
thanks,
ara
If you are talking about the 2 stroke glow engines, yes it's possable...and easy, as W8YE has indicated...done it to a couple of mine. ( .46 and an Alpha trainer version )
