Saito Carb question
My Feedback: (13)
NC
Saito Carb question
The housing for my high speed needle will not tighten up. It will not pull out, but pulls out about 1/16 of an inch. It will also turn back and forth until the fuel line catches it. I had to rebuild it about one year ago. Any ideas on how to fix it or did I miss something?
Thanks Alan
[link=http://www.horizonhobby.com/Products/Default.aspx?ProdID=SAI150S144]rebuild kit[/link]
Thanks Alan
My Feedback: (13)
NC
RE: Saito Carb question
w8ye,
The needle valve body slid in to the carb with a nut on the outside to hold it. I can't hold the body to tighten up the nut on the outside. Uless my carb is messed up from when the original carb body broke up.
Alan
Alan
My Feedback: (16)
ORIGINAL: bgfireman
w8ye,
Alan
w8ye,
Alan
My Feedback: (13)
NC
w8ye,
The high speed housing has two flat sides on it that if a wrench would fit in the carb you could hold it still with. Well I got smart and used a pair of tweezers. So it does not spin any more. One last question though. Should the low speed side slide in and out about 1/16 inch?
Thanks Alan
Thanks Alan
