Webra Engine problem
Old 07-27-2003 | 11:19 PM
Default Webra Engine problem
I have a 8 or 9 year old Webra Blackhead .61 with a bad bearing. The only markings on the engine are Webra and 10 ccm
The front housing bolts on, and I can't get it off -- seems as though the thrust washer has a pin of some sort in it. I have tried to put peices of doweling on either side of the indented thrust washer and pecking the end of the drive shaft without any success. Does anyone know about this engine? Please?
Old 07-27-2003 | 11:26 PM
Hobbsy's Avatar
My Feedback: (102)
Default Puller
A battery terminal puller from NAPA will do the job nicely. The front housing is just simply stuck and should come right off by tapping it gently with a phenolic hammer.
Old 07-28-2003 | 02:29 AM
I've got a gadget similar to that -- will give it a try. Would heating it a bit help?
Thanks for the quick assistance!!
