Need engine re-worked
My Feedback: (28)
Hey Tim. Thanks for the throttle arm, Hope to repay your generosity and fast service ten times over! BUT... Even with two sets of bearings, With and without seal, I can't get that 60 III to stop throwing fuel from around the prop. Compression is low, so I figure I might as well have you bring it back to life. If you could email me a good figure on a rebuild, (Piston and sleeve, rings if needed) I would be happy to send it to you, as I have given up.
[email protected]
Curtis Richardson
[email protected]
Curtis Richardson
