back plates
will a OS 40 fx back plate work on a OS 40 fsr.
Thanks wattmeter[:o] |
RE: back plates
A 40 SR doesn't have a back plate as it's a rear induction engine. Do you mean the 40FSR??? I have both but I'd have to check.
RE: back plates
ORIGINAL: fordman1 A 40 SR doesn't have a back plate as it's a rear induction engine. Do you mean the 40FSR??? I have both but I'd have to check. Thanks wattmeter:eek: |
RE: back plates
Just checked. A 40 FX will not fit a 40FSR. I may have a spare backplate. I'll look in my box of sapre parts.
RE: back plates
ORIGINAL: fordman1 Just checked. A 40 FX will not fit a 40FSR. I may have a spare backplate. I'll look in my box of sapre parts. |
RE: back plates
Has anyone tried to see if the backplate off a 40FP or 35FP will fit the 40 FSR?
I have both, and could check, if there is any interest. I might try it just for my own curiousity. |
RE: back plates
They won't work.
RE: back plates
ORIGINAL: fordman1 They won't work. Bill[:o] |
RE: back plates
I have a backplate for a 40-46SF part#25407000
I am not sure if it will fit your engine or not though. Maybe someone can chime in |
RE: back plates
just curious .... will a glow engine run without a back plate?
RE: back plates
Two stroke no, Four stroke yes.
Dave H |
RE: back plates
A four stroke may run without a backplate, but the con rod would be in peril if you did.
RE: back plates
...yes and not only the conrod. The Bigend from the conrod can snap out to the backside of the engine and for sure not only the conrod gets destroyed if this happens. Don't try this at home...
Kind Regards, Holm |
RE: back plates
Nope, won't fit.
ORIGINAL: d_bodary I have a backplate for a 40-46SF part#25407000 I am not sure if it will fit your engine or not though. Maybe someone can chime in |
RE: back plates
I'm leaving Friday so if you want the back plate let me know ASAP
RE: back plates
ORIGINAL: controlliner A four stroke may run without a backplate, but the con rod would be in peril if you did. Dave H |
RE: back plates
Do you still want that back plate?? It's packaged up and ready to send.
| All times are GMT -8. The time now is 11:05 AM. |
