RCU Forums
-   Glow Engines (https://www.rcuniverse.com/forum/glow-engines-114/)
-   -   Tuning a pipe to a engine (https://www.rcuniverse.com/forum/glow-engines-114/10819384-tuning-pipe-engine.html)
bob62 11-19-2011 08:41 AM
We have a Super tiger G-21 size 46, we wish to install a header and pipe on this engine. What is the process to tune the pipe to the engine. The plane will weight around 4 to 4.5 pounds with all hardware installed, also what prop would be best to run on this engine for speed
coriolan 11-19-2011 10:55 AM
RE: Tuning a pipe to a engine
http://www.macspro.com/tuning.asp
bob62 11-19-2011 11:13 AM
Thanks Bob
jaka 11-19-2011 11:29 AM
Hi!
9x7 or 9x6,5 APC. Not a Zinger or MA.
bob62 11-19-2011 12:05 PM
Thanks, I will get me some
freakingfast 11-19-2011 04:51 PM
The right prop depends on what type of plane it is. Several times I have found a Master Airscrew S-2 series prop to be faster than an APC, but usually only on a sport type plane.
Ernie Misner 11-22-2011 05:25 PM
Us the header and a mousse can setup unless you just after rpms and top end. I love headers and pipes for sport flying but not tuned for high rpms necessarily.
Ernie
Jezmo 11-25-2011 06:27 AM
ORIGINAL: freakingfast
I was doing club racing for a few years and we had a gent come in from another city near here to race with us. Most everyone was running the TT40 Pro but he was running a different brand. Not wanting to bring up engine types but rather prop differences I'll leave the brand out. He had tried everything APC made and was about to switch back to the TT40 when he decided to try a Master Airscrew on it. Needless to say he won the overall event and had done so at other events with that setup. The APC seemed to be the prop to use with the TT40 but not all engines like the same setup. I learned a lot that day and since I also was NOT running the TT40 I decided to try different props on my racer and found that indeed other brands can and do work very well. In fact, one setup worked best with an old style MA to the tune of about 3 mph on radar. (Ten runs averaged together some at 2 faster some 3 and some 4 but the average was 3) The engine was turning more rpm's on the ground with the MA and when an APC was selected that gave similar rpm the speed went back down. That's when I came to the conclusion that no one prop suites all applications. It really is all about trial and error. Some call it research and development in the racing world.
controlliner 11-25-2011 06:40 AM
I don't believe the ST G21 .46 has high enough liner timing to see much of a gain with a tuned pipe. You might do better with good prop selection.
jaka 11-25-2011 06:59 AM
Hi!
APC is not the best prop if you use a 10x6 or 10x7, then a RAM or Graupner is better. MA is no good compared with RAM or Graupner Cam-prop though!
