what you think, a Walbro for a Glow 4st
so my son has a Magnum 180 4st, it runs great and it's quite smooth and powerful, it will turn an APC 17X8W at 8800 (on 15% Nitro), as I have found that is the same as the Saito 180
the problem is I can not trust it to idle unless it has been flown, 2 things come to mind, 1) it simply will not idle well unless it gets hot in flight,, or,, 2) before flight the tank is full and the engine just runs to rich at idle,, keep in mind that if I lean the idle more it will not start well at all, so I'm sure the Low Needle is where it should be, cause if I richen it more the idle becomes worse, BTW, after flight it will idle way, way down, it will really plunk down low and will just keep on idling to add, both the High and Low needs are very, very loose, and I have tried all the Magnum tricks with the needs, so I was thinking about making a Manifold for a Walbro, it would not be that hard, the pluses would be the Walbro would have a Fuel Pump, and I think it would not be as messy to add,, I can call Walbro as I have in the past and get a Carb that fits the ID of the port that has the highest Metering so it will flow the Alcohol well yes, I will be sticking with Glow Fuel.. so I'm sure it would work, but it is important that I do not loose any power or top RPM, so my question is, do you think this setup would loose power or top RPM ?? what yeeaa think Jim |
RE: what you think, a Walbro for a Glow 4st
for glow fuel, You will likely need the Walbro Methanol rebuild kit for the carb so you can can replace the diaphragms with methanol compatible parts. Now using the methanol 2 stroke Walbro carb on a 4 stroke may wind up being too rich for a 4 stroke engine, so using a regular Walbro might work in that case. You could also get a Walbro 4 stroke engine carb and use it with the methanol rebuild kit too. They do have 4 stroke trimmer engines in the 30cc displacement range too. Thus the 4 stroke gas carb might work if it isn't set too lean on the jets.
Another thought is to use a Cline regulator and a Perry VP-22SG oscillating pump and just use the regular carb that came with the engine. But that depends on how good the OEm carb is though. Then you can also just convert the engine over to spark ignition using a CH-Ignitions conversion kit. The spark ignition engines idle much better with the more reliable spark ignition versus a glow plug. That would let you keep the OEM carb then. |
thank's for repling earlwd,
yes, I do know about the gaskets needed to be change.. and I wont care to go to gas because of the loose in power.. but do you know if the Walbro 4 stroke carbs have Accelerator Pumps in them, I don't think the Glow 4st would work well with an Accelerator Pump, what about that ?? thanks again Jim |
If you jump to the "Engine Conversions" forum you will see a couple of discussions on this subject concerning the ASP/SC?Magnum 180 FS.
Here are the threads: http://www.rcuniverse.com/forum/m_10619867/tm.htm http://www.rcuniverse.com/forum/m_9218106/tm.htm |
yes thank you, I have read them.. I know a Walbro will work, but my biggest worry is I may loose some power
Jim |
Your best bet would be to replace the engine. Magnum's seem to have runs of bad carbs and other parts. Quality keeps changing from good to poor.
replace the engine,, no way,, you sure don't know Magnum 4st's,, and with my mechanical skills why should I replace an engine just because of it's Carb..
as said, the engine is strong and smooth, it's a good engine, the Carb doesn't make it a bad engine, it's 3 years old and it has only 3 gallons run threw it I have seen Magnums run for years and years while hearing complaints about OS and Saito, I know a guy that has a Magnum 91 4st and it is 12 or 13 years old, and he flies it a lot Jim |
ORIGINAL: earlwb for glow fuel, You will likely need the Walbro Methanol rebuild kit for the carb so you can can replace the diaphragms with methanol compatible parts. Now using the methanol 2 stroke Walbro carb on a 4 stroke may wind up being too rich for a 4 stroke engine, so using a regular Walbro might work in that case. You could also get a Walbro 4 stroke engine carb and use it with the methanol rebuild kit too. They do have 4 stroke trimmer engines in the 30cc displacement range too. Thus the 4 stroke gas carb might work if it isn't set too lean on the jets. Another thought is to use a Cline regulator and a Perry VP-22SG oscillating pump and just use the regular carb that came with the engine. But that depends on how good the OEm carb is though. Then you can also just convert the engine over to spark ignition using a CH-Ignitions conversion kit. The spark ignition engines idle much better with the more reliable spark ignition versus a glow plug. That would let you keep the OEM carb then. FWIW, CR |
ORIGINAL: Charley ORIGINAL: earlwb for glow fuel, You will likely need the Walbro Methanol rebuild kit for the carb so you can can replace the diaphragms with methanol compatible parts. Now using the methanol 2 stroke Walbro carb on a 4 stroke may wind up being too rich for a 4 stroke engine, so using a regular Walbro might work in that case. You could also get a Walbro 4 stroke engine carb and use it with the methanol rebuild kit too. They do have 4 stroke trimmer engines in the 30cc displacement range too. Thus the 4 stroke gas carb might work if it isn't set too lean on the jets. Another thought is to use a Cline regulator and a Perry VP-22SG oscillating pump and just use the regular carb that came with the engine. But that depends on how good the OEm carb is though. Then you can also just convert the engine over to spark ignition using a CH-Ignitions conversion kit. The spark ignition engines idle much better with the more reliable spark ignition versus a glow plug. That would let you keep the OEM carb then. FWIW, CR Why in the world did you ever go back to GI? |
The Cline system does the same as the Walbro and you dont have to change anything else.
