ASP 180 FS gas conversion
RE: ASP 180 FS gas conversion
I fit hall sensor, magnet new hub etc
The interesting part I think is that I removed original carb and make new intake with walbro carb support. I will use a modified walbro for 4 strokes
Intake is 3 parts maiden from aluminum, and is aluminum welded
Regards Max
Regards Max
I break In engine with gasoline 30:1 mix oil. I remove back plate and cover valves and engine is fully oiled. Works nice smooth I will post video later
Regards Max
Regards Max
Nice job!And what ignition module do you use? Is 30:1 mixture enough oil to operate the engine?If the con rod is not roller bearing supported then you should increase oil content!
ORIGINAL: Nikolas K
Im Using Rcexl ignition. Oil is enought only use a high quality synthetic. I had ran my saitos with 1:40 many hours and still excellent. Hopes this ASP be too. I tested many oils. Some oils burn easy and not lubricate engine. others still with viscosity. I found that almost all 2 strokes aoils are not good, , burns very easy. I found that oils designed for mix 1:100 are better oils here in Mexico i found Amsoil excellent.
In other hand more oil, less power, and begins walbro problems
Regards max
Hi Max. Nice job [8D]
What size Walbro/type did you use? - I had most luck with 9.5mm choke and with accelerator pump (WT-38).
very nice !!
I have the Magnum 180 fs, it should be the same Engine,,
a little info, my Magnum had very little compression, it came stock with 2 Head Shims so I removed 1 Shim, the RPM came up 700 RPMs (but I run it on Glow), there is a guy here on RCU that removed both Shims (but here too he is burning Glow),, so you may want to think about removing 1 of the Shims to get a bit more power,,
I get 8850 with an APC 17x8 on 15% glow and it drinks about 1oz a minute,,
what size Prop are you using there ??
BTW,, that Engine sounds as if it needs the Rocker Arms adjusted, when my Engine was new I had to re-tighten the Head Bolts 3 times and re-adjust the Rocker Arms 3 times within the first gallon of fuel !!!
Jim
Jim
ORIGINAL: i7x58
Also a WT-456-1 or Zama C1Q-P8 will work, I did it on Satio ,FG20,FA125,FA120S,FG30,FA150 and FA180 I am working on FA 220. and I used C&H Ignitions .
Adrian
Adrian
ORIGINAL: the Wasp
very nice !!
Jim
very nice !!
Jim
Im using a 18X8 prop I dont remove head shrims but Im sure you reaay get the 700 rpm more with it
About rocket arms are you ussing 20% oil fuel?? This asp never touch nitro rwas break in wit gasoline only first 30:! now is using 40:1 and s fully oiled
May be problems with head when remove shims, something desadjust of corse when you remove itneed adjust vavles
convert it to gas
Rgards
Max
Is important engine be ok in all its parts before converting. Engine will run hotter with gas but is no a problem Firts repair it. If you want send pics and could help you
Regards Max
Regards Max
Regards Max
Regards Max
My Feedback: (34)
Its been a long time since this post, but I wanted to see for those who have converted How are there motors still running?
Im building a ESM B25 and while it would be easyer to put 2 DLE30 on it just wont have the sound I want.
So how you guys likeing your converted motors?
How is going the ASP 180?? I want to do same conversión on a new ASP 180.
Could you please give me the cost of the KIT?? I want to do it myself
Nicolas de CHile
My Feedback: (34)
I know this is a old thread, but I got 2 conversion kits from Max, for 2 new ASP 1.80 4c from HK for my ESM B25.
One of these motors I have around 5 flights on in a spacewalker, but they are both basically new.
I feel like Im low on power, Im getting 8600rpm on a MAS 15X7X3 prop which according to the calc is 2.143 hp vs 3+ that most of you ASP owners are showing.
But just reread this thread and may have found one of my issues, as Im running my oil at 20:1 as that is what I thought we needed, Im sure I may pick up a few rpms with more fuel. I will try and see if there is a diff.
16*8 on petrol with ~~8,000 RPM (or less) and 20:1 oil is right. 15*7*3 at 8,600 is good. 18*8 only OK for methanol with a lot of oil.
If you don't have a roller main bearing, don't run less oil than 20:1! It will seize!
Look here http://www.rcuniverse.com/forum/engi...-glow-gas.html
I would like to know where I can purchase just the ring to go over the hub.
Would be good to know where to buy a length of aluminium tubing and cut my own.
Need 27mm id with about 35 od.
My Feedback: (34)
Without touching the needles im now getting 9300_9400rpm at wot with the same 14x7x3 master airscrew props
They sound great
I converted my 180 to ignition burning ethanol 10:1 sintetic.
After run in I inspected and found everythink well oiled an clean, no carbon.
Measuring the parts I noted the crank pin marked and the conrod bush oval.
In the pics below You can see the pin bush with 3 oil holes, 2 downward and a third one uppward, just in the area where the pressure is higher.
I balanced the engine as per the book and made another bronze bush, only two holes down.
Have one of You met this issue???
Note 3 holes in original pin bush.
