RCU Forums
-   Glow Engines (https://www.rcuniverse.com/forum/glow-engines-114/)
-   -   Engine problem. help (https://www.rcuniverse.com/forum/glow-engines-114/11607947-engine-problem-help.html)
cap 580 dan 12-14-2014 02:22 PM
Okay so I built a eagle 580 with a os 61 engine, its side mounted. It also has the old 7m carb, this is an old engine but ran great 3 years ago.
So I go to start it and its running lean, and dies when you throttle back, I notice the engine shuts off, the fuel thats in the line goes back into the tank, is this normal?
I am thinking tank setup is bad, but I dont know. Any ideas will help.
1QwkSport2.5r 12-14-2014 03:32 PM
Whenever you have a misbehaving engine, put it on a test stand with a known good fuel system and run the engine. If it runs okay on the test stand then you know something is amiss in the aircraft. The fuel should not go back to the tank unless the tank is too low or there's a leak in the fuel system. I'd be using a test stand and nail the engine down to be 100% before doing anything else personally.
cap 580 dan 12-14-2014 04:21 PM
I agree, but thats alot of work might as well do it though
1QwkSport2.5r 12-14-2014 04:36 PM
Sure beats risking bringing your plane home in a hundred pieces, eh?
cap 580 dan 12-14-2014 05:55 PM
1 Attachment(s)
whaacha think, the line to the carb is comming from the bottom right tube. it is maybe 3/4 of an inch below the carb..
1QwkSport2.5r 12-14-2014 06:20 PM
That's likely not a major issue. I'd still pull it out of the plane.
JollyPopper 12-14-2014 11:40 PM
It appears you have an OS .61FSR engine which some folks believe was the best engine OS ever produced. Most came with a 7D carb which was also used on the 90 and 1.08 engines, and to get it to work better on the ;61, OS offered a brass insert to slip down into the bore of the carb throat restricting the bore of the carb and forcing the engine to draw fuel better. I'm not sure 7M carbs used these inserts but you might look into the carb and see if it has a brass insert in it. If not, you might try one and see how it works. Another problem could be the small o'ring on the needle. You say this engine sat for a couple years and that little o'ring could be passing air. The fact that the fuel tends to run back into the tank suggests a possible air leak somewhere. Also check the nipple on the muffler. If it is clogged with congealed oil it can cause all kinds of silly things. If none of these are the problem, check for a cracked fuel line, possibly inside the tank. A cracked fuel line on the supply line to the carb could also cause the problem. Also, does the fill line with the fuel dot on it have a clunk on it as well as the carb supply line? You definitely have a fuel supply problem and any or all of these things can contribute to that kind of problem. The .61 FSRs are a sweet running power plant when everything is right in them.
cap 580 dan 12-15-2014 05:22 AM
Yeah man the fuel fill line has a clunk too, problem?
Everything is new so i doubt cracked lines the case.
And youre telling me, when this engine runs good its a bat outa hell. its 35 is not 40 years old!!!.
the cap 580 instructions said to use a clunk line of fuel fill. which i thought was odd. is that the issue here? If so i a, curious on why
Mr Cox 12-15-2014 05:53 AM
Are you using the same type/blend of fuel as 3-years ago?
Have you tried to simply set the low end a little richer?
cap 580 dan 12-15-2014 06:01 AM
Its all new fuel tubing, will the extra cllunk in the tank cause issues.
and I have not I dont know whats what on this carb i know it ran perfect a wile back with no issues
cap 580 dan 12-15-2014 06:04 AM
Oh and yeah i am using 15% cool power its new aswell.
1QwkSport2.5r 12-15-2014 06:08 AM
If using a 3-line setup with two clunks, you may encounter issues. I did when I tried it with an ST S90. When coming off the throttle from WOT the pressure line would fill with fuel and the engine would go rich and quit. I didn't have much success in using a 3-line setup where others had success with it. I went back to using a standard pressure line inside the tank (pressure line came in above the fuel level) and my problem went away. Some exhaust systems don't bleed the pressure off quick enough when coming off the throttle in my experience.
cap 580 dan 12-15-2014 06:11 AM
I think thats my problem. I have a tank from an ugly stick, that ran this engine perfect might fit it in.
1QwkSport2.5r 12-15-2014 06:17 AM
Anytime I have an engine that is normally reliable and runs well and all of the sudden doesn't run properly in a different craft, 99% of the time the fuel system is to blame. That's why I suggested the test stand with a known good fuel tank/system to eliminate all variables to determine if it's the engine or the fuel system. I had to do this with a TT .46 where on one craft it ran like a Swiss watch and in another it wouldn't throttle or idle worth beans. WOT great, anything less and it would quit. On the test stand it ran like a Swiss watch again. Changed the fuel tank and all was well again.
cap 580 dan 12-15-2014 06:45 AM
I have the tank out looking into it now, I have some spare tanks so well see
flycatch 12-15-2014 08:29 AM
Your problem is called "vapor lock".
cap 580 dan 12-15-2014 10:15 AM
That isnt the problem, I used to fly rc helis professionally I know the engines are not much different, But i was king at tuning and troubleshooting the heli stuff,
Its not vapor lock,
Now I did some thinking, gravity is a ***** we all can agree. This planes a tail dragger. i make the plane level and the fuel doesnt go back into the tank.
I dont know if this is normal but I didnt even think about gravity being the problem, I tried a different tank and it did the same thing.
What I am doing is priming it, and seeing if the fuel goes into the tank, I tried that on both tanks and same thing. I think the tune of the engines just off, IE the idle mix.
Now this 7m carb I know really nothing about any insight would be nice
JollyPopper 12-15-2014 10:59 AM
Since the problem goes away when the tail is raised, it sounds as if the engine isn't drawing fuel up that short distance between the fuel feed line and the center of the carb. The tank appears to be about 1/2 inch below the needle valve. The pressure from the muffler produces a bit of boost for the fuel draw, but the primary force is vacuum produced by the engine. When the piston comes down (the downstroke), it produces a vacuum between the top of the piston and the head, That vacuum draws fuel through the intake ports of the sleeve much like drawing soda through a straw. If this is a ringed version of the .61FSR, the ring could be gummed up from sitting, reducing the vacuum produced on the downstroke of the engine. If that's the case, it will clear up by simply running the engine.
cap 580 dan 12-15-2014 11:03 AM
Agreed, the slime on the bottom of the plane, is a light colored brown. ill just run it and see if it gets better.
flycatch 12-15-2014 12:07 PM
Its not vapor lock,
http://www.rcgroups.com/forums/showthread.php?t=138519 Read this.
cap 580 dan 12-15-2014 12:19 PM
Good thread, honestly im going to change the plug, set the needles and see what happens
Mr Cox 12-15-2014 02:47 PM
I take it you haven't touched the carb settings at all?
The needles are there to be adjusted on, there are so many things that affect the fuel delivery that you of course have to optimise the carburetor settings for every installation, prop choice and fuel etc.
By using an extra clunk you reduce the pressure at the fuel pickup when the tank is full (compared to a regular set-up). But the advantage is that the pressure is now independent on the fuel level, as opposed to the regular installation where the pressure drops as the level drops in the tank.
So put in a new glow plug and tune the carb with the second clunk installed, it is as easy as that. For a description of the carburator you can have a look here; http://manuals.hobbico.com/osm/27481000-manual.pdf
Bozarth 12-15-2014 02:51 PM
Originally Posted by cap 580 dan (Post 11937815)
...So I go to start it and its running lean, and ....
All this fuss...run it rich.
Kurt
cap 580 dan 12-15-2014 04:02 PM
I am pretty sure i figured it out,first off i fired it up and it was running decently. if i back off on throttle sometimes itll die though. But i got to looking and noticed some slime around the muffler. my old man i guess like 10 years ago tapped into the muffler for smoke, and theres just a bare hole there now LLOL. is this this issue? i think yes
drac1 12-15-2014 11:22 PM
Internal combustion engines do not suck the air/fuel mixture into the engine. Atmospheric pressure does this by displacement. As the piston travels down, space is created which is then filled by the air which enters the cylinder through the carb opening. ie -atmospheric pressure displacing air from outside the engine to fill the space created inside the cylinder. (equalisation).
While the fuel is sucked in a little by the high speed air going past the spray bar, it is not enough for the engine to run properly. That is why we use muffler or crankcase pressure on unpumped engines. To force the fuel into the carby.
1QwkSport2.5r 12-16-2014 03:39 AM
The muffler pressure is very very low at low throttle settings though, so the engine needs to draw fuel on its own, essentially, at idle.
As the piston travels up and the crank inlet opens, a low pressure is created inside the crankcase. The pressure outside the crankcase is higher (and inside the fuel tank) which then the fuel is pushed into the carb. At high throttle settings the muffler pressure provides an extra boost pushing fuel into the engine albeit not much.
drac1 12-16-2014 03:58 AM
Not much fuel is required at idle, so low pressure is all that is required. It works exponentially.
The rest is basically what I said.
cap 580 dan 12-16-2014 05:44 AM
1 Attachment(s)
Okay. Here is my question with a picc attached, on the side of the muffler is a hole tapped for smoke, its just an open hole. there was jb weld over it but i had to take it off. now my question is, is this causing my issues, not supplying enough back pressure? if so it makes sense. let me know
init4fun 12-16-2014 05:58 AM
That is a problem because anything that reduces muffler pressure , reduces the available pressure to push fuel from the tank . By all means , seal that hole back up by whatever method works best for ya .
Course , that may not be the ONLY problem , but it's always best to start with the obvious first , and we all know OS did not sell the engine with a hole drilled there !
cap 580 dan 12-16-2014 06:04 AM
nah the hole was drilled for smoke like 10 years ago. and i fired it up it ran like a top. baby screamed. even held the plane up and shook it and it didnt die, but when i went back to idle it died sometimes.
I think this is my only issue honestly
jerdavis 12-16-2014 06:25 AM
sounds like the idle mix or midrange needle valve is too far open allowing fuel to run back into the tank. Or there could be an air leak in the idle mix system ( bad o rings) this carb has at least three orings on idle needle/ spray bar mechanism. The orings could be worn or cracked from drying out.
Jerry
f16man 12-16-2014 06:33 AM
An engine thats been sitting around will normaly have some issues with the old caster oil left over from the last run, simply clean out the carb and flush engine with new fuel reassemble carb with new o rings replace glow plug, plug that hole, start engine with the needle valve out 3 turns and tune from there, the fuel is the best thing to clean out old caster , after all thats what put it there in the first place..........
cap 580 dan 12-16-2014 06:53 AM
the more i run it the better it gets, so once i plug that hole ima just maiden this thing.
Mr Cox 12-16-2014 07:02 AM
I still don't see any real problem, it just sounds like it is set too lean, have you even touched the needles?
If the needles were not needed, they would simply have omitted them from the beginning...
cap 580 dan 12-16-2014 07:36 AM
yes ive touched the needles.
cap 580 dan 12-16-2014 03:44 PM
Anyone wanna play a guess that engine game? also got mine running perfect
mike31 12-16-2014 06:32 PM
In lieu of acting not to smart is the 61 ringed or abc? If ringed could be a stuck ring in the ring groove. Just a thought.
vertical grimmace 12-16-2014 08:19 PM
Just an FYI, if you did not know, the 2 clunk system is known as Uniflow venting. Common with control line models. You want one clunk attached to your carb line, and the other clunk connected toy your muffler pressure line. Not your fuel dot. This helps maintain a consistent needle setting throughout the tank level. Typical problem is to go lean as fuel level drops. This eliminates this issue.
JollyPopper 12-17-2014 11:44 AM
A clunk on the exhaust pressure line? Would that not blow a lot of bubbles in the tank, a condition to avoid at all cost? The reason I put a clunk on the fill line (fuel dot) is so that I can de-fuel the tank through the fill line at the end of a flying session.
vertical grimmace 12-17-2014 01:09 PM
Look up "Uniflow" venting. A sI am sure nobody will take my word for it, and I really do not feel like trying to explain it. It works. Bottom line.
