RCU Forums
-   Glow Engines (https://www.rcuniverse.com/forum/glow-engines-114/)
-   -   Engine pump beguiners Question (https://www.rcuniverse.com/forum/glow-engines-114/1829513-engine-pump-beguiners-question.html)
norbe 05-19-2004 05:50 PM
Just a fast and easy question I am installing a TT120Pro engine with pump, the engine has a pitts bisson mufler with the mufler pressure exit, should I connect the pressure exit to the tank or not?
Norberto
William Robison 05-19-2004 06:06 PM
RE: Engine pump beguiners Question
Norberto:
No.
The tank needs a vent though. Either leave the muffler port open or cap it, doesn't matter.
Bill.
Azcat59 05-19-2004 07:47 PM
I have two of these engines, both with Perry P-30 pumps. Bill is right. Just vent the tank to the outside of the fuselage and use no muffler pressure.
Clair
norbe 05-19-2004 11:20 PM
Ok thanks for the tip, I will do as you advise. Thanks Norberto.
