RCU Forums
-   Glow Engines (https://www.rcuniverse.com/forum/glow-engines-114/)
-   -   Velocity Stack (https://www.rcuniverse.com/forum/glow-engines-114/1844609-velocity-stack.html)
TNRabbit 05-25-2004 11:19 AM
Velocity Stack
I'm trying a velocity stack on my Rossi .45 to try and reign in some of the "splatter" that occurs when running at WOT & would like to solicit ideas/comments from anyone else who has tried this. Rpm increase/decrease? Fuel Economy increase/decrease?
William Robison 05-25-2004 12:00 PM
RE: Velocity Stack
1 Attachment(s)
Gary:
Two ways to control the splatter out the intake. One is an air filter, such as the BruLine from Tower Hobbies, the other is the inlet stack.
First picture is my Magnum 25 with a stack that I put on it as an experiment. I didn't notice any power increase, but the plane stays a lot cleaner with the out spray controlled, and the fuel economy seems to have gone way up. And it may be subjective, but it seems easier to tune also.
Second and thirs pictures are a Saito FA-120 with both the stack and the BruLine filter. The combination made a very nice engine even sweeter.
Bill.
TNRabbit 05-25-2004 03:17 PM
RE: Velocity Stack
Did you use the coarse or fine bruline filter on the Saito?
William Robison 05-25-2004 04:17 PM
RE: Velocity Stack
Gary:
The BruLine coarse element will keep gravel and small birds out of the engine. I use nothing but the fine elements. Sorry, I shoud have said that earlier.
If you have the fine element clogging rapidly you are in an area where you shouldn't be flying - the trash in the air will get you too.
Bill.
William Robison 05-25-2004 04:25 PM
RE: Velocity Stack
1 Attachment(s)
Gary:
More. I also have the BruLine filters on Magnum and K&B, with the same increase in fuel economy.
Coouple more pictures. First is a K&B 61 in my Diablo, second is a Magnum, the right engine in my C-3/10.
Bill.
TNRabbit 05-25-2004 04:46 PM
RE: Velocity Stack
I would think the filter would create a significant loss of top end power....?
William Robison 05-25-2004 05:01 PM
RE: Velocity Stack
Gary:
I've not noticed any power loss. Even the fine element isn't very restrictive.
Bill.
jessiej 05-25-2004 06:15 PM
RE: Velocity Stack
ORIGINAL: TNRabbit
The only engine that I have done any with/without filter comparisons with is an OS 1.08. There was no RPM difference, and as best I recall little if any NV adjustment.
jess
