RCU Forums
-   Glow Engines (https://www.rcuniverse.com/forum/glow-engines-114/)
-   -   G75-G90 differences? (https://www.rcuniverse.com/forum/glow-engines-114/2012548-g75-g90-differences.html)
David74 07-22-2004 03:03 AM
Why should I buy a Supertigre G75 instead of a G90? The G90 has more power in the same dimensions and price is just 7-8 bucks more… the only thing I can think of is the different fuel consumption. Is that an issue?
thanks
david
JIMBO D 07-22-2004 04:37 AM
RE: G75-G90 differences?
Go for the 90. You can always throttle back or put a larger prop on it if its a bit over powered. Also you have more scope for future planes. Fuel consumption will be slighly more only if you are using the extra power
Jim
w8ye 07-22-2004 07:09 AM
I have a couple of G90's. I second what Jimbo says
Enjoy,
Jim
Hobbsy 07-22-2004 07:47 AM
Jim, Sport Pilot and I each have a Super Tigre .90 with the big S on the side and the bolt on front end. Are these the revving .90s or the luggers, or is that not enough info, I intended to ask you that yesterday and I plum fergitted. Thanks
w8ye 07-22-2004 09:09 AM
The G90 with the one piece crankcase with the larger rear bearing and the smaller intake passages is considered to be the lugger. But I still like the 14-6 or 13-8 on the G90's. I've tried the 15-8 and 16-6 on them and they perform like the book says but spool up from idle is slow. They would perhaps, work 'OK' in a scale situation where you were trying to get out beyond the cowl. I get 11,000 with a 14-6 APC and the 108 carb. The 40 carb only gives you about 10,000.
The S90K is the one you are talking about with the two piece crankcase and the squarish head. They look somewhat more massive than the G90.
The S90 is the one with a crankcase a lot like the S90K but it has a round machined head that is sunken in the middle.
The last truely Italion made G90's to come from Italy had a '40' carb on them for some reason. They do a lot better even with the big props when using a ST carb with the flat sidded spray bar or by using a Magnum 108 carb which bolts right in.
They all seem happy with a 14-6. prop
In a diesel situation, the round sided spraybar '40' carb would be better.
Enjoy,
Jim
Sport_Pilot 07-22-2004 09:34 AM
Not sure what you mean by round sided. My carb appears to be about .60 sized, maybe slightly smaller, has slotted needle on the idle side.
Hobbsy 07-22-2004 09:41 AM
ST has two styles of spray bars, round ones and ones with both sides ground flat to increase the venturi flow area. I have a lot of ST carbs, I use them on other brands that have iffy stock carbs because the ST carbs are infinitely tuneable.
Sport_Pilot 07-22-2004 09:47 AM
So I should expect about 11K with a 14-6? What fuel, is it limited to low nitro? I have a red head ASP .91 that turns a 14-6 well over 11K but cannot use over 5% nitro. Also weighs a bunch more.
Hobbsy 07-22-2004 10:19 AM
1 Attachment(s)
Spraybars
Kweasel 09-29-2004 12:09 AM
My S75 is a very user freindly engine, a little more so than my g90, the 90 will pull a 14-6 zinger 10,400 and the 75 will only make 10,000. I used both engines in the same airframe and the power differences diminish if you prop the 75 to turn about 1000 more rpm. The 75 with a 12-8 performed about same as the G90 with a 12-10. The 90 WILL cook a piston faster if run too lean for too long.
FlyingPilgrim 09-30-2004 08:47 AM
If a person was looking between these two engines with the intentions of mounting it on a Top Flite warbird, you might want the .75. The .75 will run with the Top Flite in-cowl muffler , but it is too restrictive for the .90, and will cause it to overheat. Other than that, the only reason to buy the .75 over the .90 would be if you got a really great deal on it.
Pilgrim
r1derbike 10-25-2004 07:16 PM
My brother put a 90 in a 60 size extra...the larger prop would ground-out on takeoff or landings. He wasn't happy, and had to make larger main gear (taller), which made the model look "odd".
Charles
r1derbike 10-25-2004 07:21 PM
Oh! Having said that above...I just ordered a .75 to put in my .60 size extra... ;-}
Charles
