RCU Forums
-   Glow Engines (https://www.rcuniverse.com/forum/glow-engines-114/)
-   -   Engine Transition Stall (https://www.rcuniverse.com/forum/glow-engines-114/2014342-engine-transition-stall.html)
Skullder 07-22-2004 04:46 PM
I had a .52 Vmax 2 stroke on my LT-40 a while back and whenever i throttled up really fast right before takeoff the engine would stutter a bit and stall, but would not if i throttled up slowly.
In the air i never had any engine failure problems.
Anyone know why this is?
ptgarcia 07-22-2004 04:51 PM
RE: Engine Transition Stall
You may be a little rich on the low end, and while idling before take off it loads up a bit. Try leaning the low end (close the needle) ever so slightly until you get a smooth transition. Good luck!
Skullder 07-23-2004 01:17 AM
will do, thanks!
