RCU Forums
-   Glow Engines (https://www.rcuniverse.com/forum/glow-engines-114/)
-   -   O.S. Engine (https://www.rcuniverse.com/forum/glow-engines-114/2064162-o-s-engine.html)
hickox 08-07-2004 09:51 PM
O.S. Engine
New O.S. FL 70 Leaking Fuel / Oil. Mostly oil from rear engine plate. Help. Plsatic Warped?
voyager_663rd 08-07-2004 10:42 PM
RE: O.S. Engine
Undo the rear plate bolts, pull it off and check to see if the gasket is warped/bent/deformed or maybe a smidgen of dirt is preventing full contact. Even if you can't see any dirt, clean it off GENTLY and reinstall. Remember to tighten the bolts crosswise a bit at a time, just like tightening the wheel bolts on your car.
jaka 08-08-2004 02:55 PM
RE: O.S. Engine
Hi!
Isn't the oil just coming from the breather nipple on the crankcase...?
Regards!
Jan K
Sweden
William Robison 08-08-2004 04:59 PM
RE: O.S. Engine
Matt:
JanK has a good point, but it wont hurt to check the sealing also. Put some RTV on the joint as you reassemble, that will take care of any warpage in the plastic cover.
Bill.
w8ye 08-08-2004 09:46 PM
RE: O.S. Engine
I don't remember there being any gasket on the back plate? The oil is probably coming from the breather?
Enjoy,
Jim
hickox 08-12-2004 06:41 PM
RE: O.S. Engine
Thanks Guys.
The bottom end was just set way to rich. Leaned it out from the factory setting and the oil stopped.! Thanks for the HELP.
