4-stroke vs. 2-stroke....?
which one should i get for my SIG Senior Trainer (80" wingspan) i'ma lookin' at the magnum .61 4-stroke or the .46o.s.
RE: 4-stroke vs. 2-stroke....?
4 stroke, hands down.
I currently have a Magnum .91 on mine. Overpowered, but fun! This big plane really needs a 4-stroke to sound right on a fly-by. I vote for the .61!
Go for the Magnum .61 4-stroke.
I'll agree withthe 4s engine also. But if you do go with a two stroke get the XLS 46 Magnum engine.
Bill. |
IMO the extra power from an oversized engine is just not that fun on this plane. I had a .46 TT on mine to start and had to add a ridiculous amount of down thrust. Put an older K&B .40 on it and it powers it just fine except it could use more power on hot days. Thinking of putting a modern .40 on it or a .52 sized four stroke. The .61 may be OK, but a .70 would be too much. It flies fine overpowered with a lot of down thrust but you tend to fly half power except for the initial climb out. I would rather put the hotter engine on a fully aerobatic airplane. I can't say that using the four stroke would be any better.
But that is just my opinion, if overpowering a floater is fun to you, then by all means do so. There is one at our club with a .61 K&B at our club, but it is weighed down with a remote video system. |
I knows it a big plane while keeping itself light enough but I am a little sceptical, perhaps with a 46 for real easy flying. I think the Magnum 61 4C is a 'better' choice since you wanna have an easy flyer. You can hear it putter away ...
Get the Magnum .61 four stroke, I love mine, plus they are on sale @hobbypeople*net for only 119.99 ($50 bucks off!!!). A Bargain!!
BTW If you get a two stroke, get the OS .46 AX, I have that also and love it, only requires a back flip of the spinner and it is purring like a kitten. |
I knows it a big plane while keeping itself light enough but I am a little sceptical, perhaps with a 46 for real easy flying. |
I have a Saito .65 on mine, seems like the engine is just right for this airplane.
HI!
Don't be fooled to put on a too large engine on a high-winged trainer!! Low weight is the rule of thumb too good flight behavior.Not lot's of power! A 7.5cc too 8.0cc two stroke is a good choice. The MVVS .49 is the engine of choice with a 12x4 APC prop. Can't see why people fancy four strokes ...they don't sound like "real" airplanes at all..just put, put, put,......;) Regards! Jan K |
ORIGINAL: jaka Can't see why people fancy four strokes ...they don't sound like "real" airplanes at all..just put, put, put,...... Listen: * [link=http://www.whitetyphoon.com/rc/gsp_spit_show_pass.mpg]No Put Put Here[/link] * [link=http://www.whitetyphoon.com/rc/h9_corsair/movies/HighSpeedPass02.mpg]No Put Put Here Either[/link] * [link=http://www.whitetyphoon.com/rc/h9_corsair/movies/HighSpeedPass03.mpg]And Definitely No Put Put Here[/link] |
Richard L, This is what I get when analyzing your third video using matching generated tones:
Perceived rpm approaching: 14,100 Perceived rpm departing: 10,500 Now applying Christian Doppler's wisdom: Actual revs at bottom of dive: about 12,000 Speed: 113 mph (181 km/h) Good speed - what model, engine and prop is that? |
ORIGINAL: Harry Lagman Good speed - what model, engine and prop is that? Model: Hangar 9 F4U Corsair Wingspan: 65.25" Dry Weight: 10 lbs Engine: YS 110FZ four stroke Prop: Graupner 15x8 two blade Fuel: Powermaster YS 20/20 |
Yeah, it's funny - the pitch and revs suggest something around the 90mph mark but my estimates suggest more. There is an opportunity for inaccuracy when attempting to match tones with engine noise but it's usually not too far out. Also, the models can slow down significantly and reduce revs once the dive levels out which can skew the departure rev reading.
It might be 90mph, but watching the video, it sure seems pretty quick! |
Harry:
A 15x8 prop at 12K rpm, allowing only 10% slip, is flying at 82 mph minus a hair. The 8" pitch at 16K rpm is still not quite to 110 mph if we allow the same 10% slip. Bill. |
The Sig Senior needs quite a bit of weight in front to balance. Mine, with the .91 balances perfectly. If you gotta add weight, I vote for weight that does something!
Yep, I got a lot of weight in the nose of mine. But why put a .91 on it when a .40 does fine? The .91 is in a Fokker Triplane.
....I'd put a Magnum .91 FS in it. The 80 inch plane will be a dog with the .61. :eek:
FBD. :D |
The 80 inch plane will be a dog with the .61. Also a great trainer! Slower than others which gives the newbie more time to react. |
Thre ain't no supercharger in a YS- but it is supercharged.
I reworked some supercharger equipped OS 1.2 engines - what a mess- got em to perform reliably but that had to be the worst bit of piss poor design work I ever saw coming from OS. Anyone who understands supercharger applications thoroughly, would ever do that. |
I meant to say "Super Dog" ! :eek:
Dave. :) |
THANKS FOR ALL THE REPLIES FOLKS. THIS IS THE BEST SITE ON THE NET I'VE FOUND IN THE 3 YEARS OF HAVING A COMPUTER.[sm=sunsmiley.gif]
i like'um cause they sound so cool,and they look so darn good.
ORIGINAL: jaka Can't see why people fancy four strokes ...they don't sound like "real" airplanes at all..just put, put, put,......;) |
| All times are GMT -8. The time now is 02:54 AM. |
