4 strokes
any one know of a good power house 40 sized 4-stroke engine. i just bought a saito 82 and not quiet satisfied i like ys but they need to make something in between the 63 and the 1.10. anyone got anyideas??:)
RE: 4 strokes
Look at the RCV engines. Their .56 is about 40 size. From what I am seeing they make pretty good power for their size.
RE: 4 strokes
The RCV .58CD is a nice engine, but it ain't no powerhouse. It will never put out as much power as the Saito 82.
I agree that YS needs to make something in between the 63 and the 110, like an 82 or 85. |
RE: 4 strokes
yeah the rcv is totally not what im looking for lol but thanks anyways. so anyone out there got a fairly fresh ys .91 or perferably 1.10 dz they wanna trade for a saito .82 with about a gallon of fuel through it??:eek:
RE: 4 strokes
What kind of numbers are you getting from your Saito 82? Mine turns a 13x8 prop about 300 rpm more than my O.S. 91 Surpass. Unless yours has a problem, you won't find a stronger 40-size 4-stroke, unless you shoe-horn a Saito 100 or YS 91/110 into your plane.
RE: 4 strokes
also what fuel are you running? saito's run great on heli fuel, 30% nitro and high synth oil content.
RE: 4 strokes
Speaking from physical size and fit or anything else I don't think I would call a YS91 or YS110 a 40 size engine. A Saito 72, 82 or a YS 53 or 63 are "40 size" drop ins. If you are looking for the kind of power produced by a "power house" 40 size 2 stroke, i.e. Jett 40/50, YS45 or even Webra 50, Rossi 45/53 etc, etc your not going to get it with a 4 stroke that is a drop in fit for those engines.
Denis |
RE: 4 strokes
yeah i own a rossi 53 and before i bought this saito i was going to buy a jett 76L (same size as a os 46!) thats awesome! on the saito i am running ys 20/20 fuel dont know what numbers im getting but just not happy with the performance really that and its totally weird getting used to t the way a four strokes power delievery is, kinda have to learn to hover all over again and u have to keep alot more power on all the time.
RE: 4 strokes
sounds like a prop issue. Try a 15x4 or even a 14x4W APC and you may be happier with your engine.
RE: 4 strokes
Jacak-26,
I've got a YS 91AC in the box, one way valve, and manual. It only has about 30 min running time. What else in addition to the Saito 82 do you have to trade? Before I change my mind man. Carlos |
RE: 4 strokes
well i put my tach on it last night this is whats up ys 20/20 fuel alittle over a gallon ran through it, apc 15x4 prop and i was getting about 9100 rpm peaked does that sound close??
RE: 4 strokes
i dont know carlos what else u want lol i have a rossi .53 but theres no chance ill be letting go of that anytime soon let me know. the 91 its not supercharged is it?
RE: 4 strokes
Please do your trading in private, Thanks
RE: 4 strokes
9100 rpm with an APC 15x4 sound right for the 82a...and your not happy with that?
RE: 4 strokes
All YS 4 strokes are supercharged. Some use a separate air chamber and the rocker cover as an accumulator and some just use the rocker cover and intake plenum as an accumulator. But all are supercharged.
I found on the Saito 72 using a 13/6 prop that 20/20 gave me little or no improvement over 15/18 but when I used 30 percent heli fuel (30/23) with low viscosity oil I picked up 600 rpm. I went from 10200 adjusted for flight to 10800 aff. That really surprised me. I also tried 25/20 and only gained a 100 rpm. I think it was the low viscosity oil in the heli fuel that helped. All the fuel was powermaster. Denis |
RE: 4 strokes
You really should try the 14x4W APC and Coolpower 30% heli fuel before giving up on it. The Satio 82 is the most powerful 40 size drop in engine available. If you need more power then use a Satio 91 or 100. What plane is this engine in. Most of the time a YS 63 or Satio 72/82 are plenty for 40 size planes doing 3D if setup with the right fuel and prop. Also that Satio might need some more breakin time to give full power. Satios need a couple gallons to break in completely.
RE: 4 strokes
the .82 is in a fazer of all things lol. but i totally swaped the empanage off a CG ex-treme 330 the stock rudder and elevator are extremely inadequet. its a little heavy for its size about 5 lbs but im just waiting on my omp katana to come in wich should be almost a half pound lighter so i am taking that into account also. but i just want it to pull out of a hover HARD! lol maybe im crazy....probably :D
RE: 4 strokes
If your plane really is NO MORE than 5 lbs the Saito 82 with a 14/4 and 30% heli should snap it up out of a hover or straighten it with a blip of the throttle with good authority. My experience says that 5 lbs is about the max for a YS63 or a Saito 72 and still have good snap remaining.
Denis |
RE: 4 strokes
yeah ill try a 14x4 been doin with a 15x4 but i dont plan on runnin any 30% heli fuel its to hot here to be runnin that right now and its not good on the motor in the long run (granted 20/20)isnt much better. well it pulls out ok but i want more, so i can drag race my buddies verticle lol! and i dont know how much is too much thats always been a problem
| All times are GMT -8. The time now is 05:18 AM. |
