RCU Forums
-   Glow Engines (https://www.rcuniverse.com/forum/glow-engines-114/)
-   -   Question about pipe for TT91FS (https://www.rcuniverse.com/forum/glow-engines-114/2334147-question-about-pipe-tt91fs.html)
cruzomatic 11-10-2004 08:23 PM
I was flying my H9 AT-6 a couple of days ago when the pipe just broke apart in flight just before the lock nut on the muffler end causing a flame out. Thankfully, I had enough altitude to go 'gear down' and land the plane without incident. Now I need a pipe, any one know where I could get one?
Thanks.
mentorman 11-11-2004 05:18 PM
RE: Question about pipe for TT91FS
yes, try www.ehobbies.com for thunder tiger parts. they had everything i needed for mine, you may need to call them though unless you like looking at the entire tt parts listing.
tande 11-11-2004 06:50 PM
Replace it with an "OS 91 surpass" pipe---same thread, but thicker material---Been there/Done that---Or replace the entire muffler assy. with a www.pspec.com muffler & be happy ever after!---another TT pipe will simply break again---
cruzomatic 11-11-2004 09:11 PM
Thanks, I may have to go with an after market setup. I just got off the phone with Ace Hobby. They told me to send it in for inspection. Not sure what they have up their sleeve. I have two of these engines. I'm glad I was able to land the plane after the pipe broke in flight without crashing it. Thank God for altitude and airspeed. ;)
Sport_Pilot 11-12-2004 12:06 AM
Don't go with the OS muffler, it is a bit more restrictive. The tube (is that what you are talking about?) may or may not be thicker, I never noticed that the OS tube was thicker though it may be.
tande 11-12-2004 10:03 AM
Yes, you're right; Don't use the OS muffler (Which I did not suggest) use only the pipe---Yes it is heavier gage material---
