OS 61FX help
Hey guys...I bought a load of stuff from a guy who was moving onto other pursuits, and found myself with the above-mentioned 61. No manual... Can you loosen that brass nut and rotate the fuel inlet to the carb? (Don't want to go after it w/ a wrench and ruin anything) Thanks![8D]
RE: OS 61FX help
Good question...I just installed one myself, but the needle was the right way, so I never even tried to move it...you can always download a copy of the manual from www.osengines.com....I'd look for my copy, but it is somewhere under a pile of magazines and I just can't put my hands on it just now!
RE: OS 61FX help
I know that some with a remote needle have a hole inside it and the nipple has to be 180 degrees or similar either way to line up. If you move it just a tad no fuel will go in.
RE: OS 61FX help
I have had 2 of these engines and the answer is YES. You can rotate the inlet. Also, the needle valve can be moved to either a side or top facing position. Remove the brass nut and swap it with the needle valve assembly if you want to swap positions.
RE: OS 61FX help
Thanks for the replies. I'll monkey with it to suit my install. Plumbing used to be sooo easy. Now with remote needles and rearward carbs and what not, things are a little different. <Sigh> The times they are-a changin'....
| All times are GMT -8. The time now is 12:04 AM. |
