RCU Forums
-   Glow Engines (https://www.rcuniverse.com/forum/glow-engines-114/)
-   -   what engine is this? (https://www.rcuniverse.com/forum/glow-engines-114/2550483-what-engine.html)
bigchap 01-17-2005 01:39 PM
i thought i knew a bit about motors but this one has got me foxed,it is non-rc with a black plastic venturi,takes standard size plugs,the muffler is an aluminium ring sandwiched between lower cooling fin and case a la cox,the muffler has 1 hole about 3mm for the gases to exit,it is marked as a 15 but doesn't look that big and the case has what looks like a 'j' cast into it,the case backplate screws into the case,it has beam mounts as well,help.
Hobbsy 01-17-2005 02:34 PM
RE: what engine is this?
It sounds like a PAW, they either made or converted a few to glow engines at one time according to a poster here a whole back.
bigchap 01-17-2005 03:05 PM
it's not a paw glow conversion as i already have one of those.
Hobbsy 01-17-2005 03:08 PM
I guess by your description it it looks somewhat like a PAW.
bigchap 01-17-2005 04:03 PM
no.it looks nothing like a paw,my gut feeling is that it is russian or czech.
gcb 01-17-2005 08:15 PM
1 Attachment(s)
Sounds like a Cipolla Jr. although I thought they only came in the .09 size. Mine is an earlier version.
George
Edit: The 15 is actually 1.5 which means 1.5cc or .09 ci.
bigchap 01-18-2005 02:17 AM
thats the one!who made them?btw many thanks.
DarZeelon 01-18-2005 04:21 AM
Cipolla is Italian for 'onion' (pronounced "chi-po'-la").
I hope it is not a 'lemon'...
<GGG>
gcb 01-18-2005 10:21 AM
bigchap,
A little additional info, I was thumbing through a 1978 Aero Modeler magazine and saw an advertisement with the muffler version you describe. From what I understand, the Cipolla glow has a decent reputation but the diesel version tends to throw conrods. I do not have the diesel version so I am only repeating from what I've read on the web.
After I broke mine in, I found the lower conrod fit to be a bit loose, but this may be normal. I don't have a lot of time on it.
George
bigchap 01-18-2005 05:02 PM
thanks for the help
