RCU Forums
-   Glow Engines (https://www.rcuniverse.com/forum/glow-engines-114/)
-   -   ST 45 ABC problem (https://www.rcuniverse.com/forum/glow-engines-114/2597786-st-45-abc-problem.html)
jdmachinery 01-29-2005 12:22 PM
ST 45 ABC problem
RE: Super Tigre GS 45 ABC
Just crashed a Rascal 40 w/ 45 (great combo) due to pilot error. Would appreciate any answers to:
1. Upon engine disassembly, noticed the allum prop hub has run-out. Looks like oem deffect. Suspect crank was dialed & IS DEAD TRUE! Cant believe it. How does one remove alum hub? Should I try to reseat it...or buy a new hub? The spinner backplate did run w/ some run out.
2. Is there a performance issue w/ removing & reinstalling the ABC piston / sleeve??
Hobbsy 01-29-2005 12:35 PM
RE: ST 45 ABC problem
Since you crashed it the prop was bent in the crash. Use an automotive battery terminal puller to remove the prop driver.
jdmachinery 01-29-2005 12:44 PM
It was a violent crash & not the first one. If the prop driver deformed berfore bending the crankshaft, I'm gratefull SuperTigre designed it to fail. The ST has been a great runner.
Duane-RCU 01-30-2005 01:23 PM
Buy a new hub....Very cheap.
