RCU Forums
-   Glow Engines (https://www.rcuniverse.com/forum/glow-engines-114/)
-   -   anyone using a dynamix carb? (https://www.rcuniverse.com/forum/glow-engines-114/2598233-anyone-using-dynamix-carb.html)
cstewa 01-29-2005 02:43 PM
I was wondering if anyone was using an old dynamix carb and knew how to set up the ball linkage with a modern day servo. Where can I find the parts?
I am just getting back into the hobbie and found that my Webra's .61 TNII carb was broken and didn't want to buy a new carb because I want to get into 4 strokes. So anyway I mounted an old k&B 61 on the run stand and was going to put it into my super sportster (it was runing the webra). So anyway I ran the K&B and got setup for good idle and then for I found the old dynamix carb and for the heck of it I stuck on. In about two flips of the stick I remembered why I like the webra so much. It has a tuned piped and sounds so awesome. so quiet at idle compared to the K&B i couldn't believe it. Also the power difference. WOW. It has to be almost twice the pull. Do you that is normal or is something wrong with the K&B.
So I would like to use the dynamix carb and just back up flying. Any idea's. Thanks.
w8ye 01-29-2005 03:00 PM
RE: anyone using a dynamix carb?
My K&B 61 C. F. Lee specials are the hotest 61's I ever owned. Something must be wrong with yours?
Enjoy,
Jim
cstewa 01-29-2005 05:06 PM
I have noticed alot of fuel on the font of the case while running it on the stand. Must be leaking from somewhere. I like the webra anyway just can't figure out what to do with this durn ball linkage!!
Rudeboy 01-29-2005 06:15 PM
1 Attachment(s)
I fail to see what the problem is... you just pop the ball out of a standard ball link, and then pop the "empty" ball links onto the ball of the carb linkage... fits like a glove...
cstewa 01-29-2005 11:46 PM
thanks rudeboy...I will give it a shot....Thank you for the pics. I guess I didn't realize they would just pop on there.
