RCU Forums
-   Glow Engines (https://www.rcuniverse.com/forum/glow-engines-114/)
-   -   Cheapy on a pipe (https://www.rcuniverse.com/forum/glow-engines-114/2719264-cheapy-pipe.html)
McFlyboy 03-02-2005 04:42 PM
Cheapy on a pipe
Does anyone know if a Thunder Tiger 46 Pro will come on to a pipe?? Thinking about one for a pattern plane but i'm greedy for performance so I want a pipe. Thanks in advance
jaka 03-02-2005 04:59 PM
RE: Cheapy on a pipe
Hi!
Of course it will ..like most engines will!
Regards!
Jan K
Sweden
McFlyboy 03-02-2005 05:03 PM
Ok, thanks very much, I'll give it a go. Do you know of a reliable method for finding the starting length, I've got a piped 48 on another plane and everyone tells me to do different things, one told me it was too short, so I lengthened it, then another (semi-pro) told me to make it even shorter than it was before???!!!! I did find a formula on an Australian pattern site but that didn't seem to help.
Oh, the joys, :)
Thanks for the help.
w8ye 03-02-2005 06:03 PM
http://www.macspro.com/tuning.asp
Read these?
You will need to run a smaller prop so the engine will get up into the rpm area where the pipe will be more effective.
Enjoy,
Jim
McFlyboy 03-03-2005 08:16 AM
Excellent, thats EXACTLY what im looking for. And looking at that i'd say my 'even shorter' pipe is still too long. Problem is, with it being for a pattern model, noise is a big thing, and I don't really want it spinning at stupid revs, was hoping to load it up a wee bit and keep the revs down to about 11k? any thoughts?
w8ye 03-03-2005 08:29 AM
Hi revs = short pipe
Low revs = long pipe 11,000 is low
Enjoy,
Jim
Mighty Mouse-RCU 03-03-2005 09:11 AM
If you are looking to turn only 11k with the TT .46, you surely dont need a tuned pipe. Tuned pipes are generally is for seeking high performance at high speeds. Generally "tuned" for a small range of rpms. I doubt the TT .46 running a pipe at 11k will affect the performance of your pattern airframe. I'd stick with the stock muffler.
w8ye 03-03-2005 09:15 AM
Well said
Enjoy,
Jim
McFlyboy 03-03-2005 12:37 PM
It was just to turn a bigger prop comfortably. Was looking for 12x7 to get some decent performance out of the verts, but ok. Cheers for all input guys.
w8ye 03-03-2005 12:45 PM
Running at 11,000 you will not get enough from a pipe to make it worth the expense.
You get up to 15,000 and the pipe will do some work for you.
Enjoy,
Jim
downunder 03-03-2005 07:58 PM
11,000 is very close to the revs usually turned with piped engines in CL stunt. An OS 40VF with a pipe at these revs (set at about 18" from the plug to the first baffle) is considered by the experts as having roughly the power of a muffled 60. In this application the pipe is boosting torque at around the peak of the torque curve which means you can turn a bigger prop. This is what was done with the old OS Hannos to make them turn a 12x12 prop (at even lower revs, something like 9,000). The other thing the pipe then does is if the engine tries to speed up when prop load decreases in a dive then it goes off the pipe and holds the revs more constant so it's a governing device as well.
w8ye 03-03-2005 08:05 PM
I've been waiting for you to say that. I read this in a magazine some 15 years ago but have never heard it repeated since.
I've thrown this theory up on here several times and no one ever responded good bad or ugly.
Jim
Razor-RCU 03-03-2005 09:21 PM
The Tower muffler is an easy bolt on performance enhancer @ $15- The Ultrathrust or Jettstream would do better but more $$
Razor-RCU 03-03-2005 09:22 PM
Is the "piped-48" a K&B Screamin' 48? I love those...
McFlyboy 03-04-2005 07:24 AM
ORIGINAL: Razor-RCU
If I tell you, you gota promise not to laugh?
Ok, (whispering) it's an mds. Shush, don't tell anyone. ;)
ORIGINAL: Downunder
This is what I've been looking for. I knew the pipe would have to be long, but 18inches? [X(] As to the governing factor, this is a very clean airframe without the drag needed to fly constant speed style pattern so thats gonna help plenty.
I know this plane flies much better on a 60, but I've already drilled the firewall for a 40 mount, and a pattern plane without a pipe is like pancakes without syrup.
ORIGINAL: w8ye
Jim
I knew something like this existed, the OS 140 that was/is used for pattern has a pipe about two foot long but runs at low revs, just didn't wanna open my gob in case I put my foot in it.
ORIGINAL: w8ye
Last quote, I promise
I've already got a pipe to use so I'm just trying to use what I got.
Thanks again guys, this is a lot better than I could have hoped for. [8D]
