RCU Forums
-   Glow Engines (https://www.rcuniverse.com/forum/glow-engines-114/)
-   -   muffler problems (https://www.rcuniverse.com/forum/glow-engines-114/2955055-muffler-problems.html)
rccub 05-08-2005 11:21 AM
muffler problems
i have an older saito 1.50, and cant keep the muffler on it. the pipe stays screwed into the head, but the muffler itself keeps backing out. now, after a few times of coming loose and vibrating, it wont screw up tight anymore. is there something i can do to fix this without replacing the muffler. thanks.
charlie
Flyboy Dave 05-08-2005 11:30 AM
RE: muffler problems
Try some teflon plumbers tape, use it on the threads in the head too. ;)
FBD. :D
w8ye 05-08-2005 02:54 PM
Do you have the locking nut jammed up against the muffler? I was wondering if you had lost the nut?
Enjoy,
Jim
rccub 05-08-2005 08:52 PM
the jam nut was tight against the muffler. i guess after vibrating so much, the threads are not the best anymore. thought about j.b. weld, but didnt think it was heat proof. thanks.
charlie
w8ye 05-08-2005 08:56 PM
The new mufflers and pipes are made different. If you want to replace one componnent, you will have to buy6 the whole assembly to get it to work.
JB weld will work pretty well in a captive situation like locked in the threads.
Enjoy,
Jim
gjeffers 05-08-2005 09:02 PM
i used red high temp locktite threadlocker on that exact spot and it hasent moved in 4 mos;)
Flyboy Dave 05-08-2005 09:52 PM
See if you can balance the prop, spinner, and back plate....and cut down on
the vibration. It shouldn't be throwing the muffler off like that. [:o]
FBD.
onewasp 05-09-2005 06:09 PM
----and with Red Locktite it probably wont move ----EVER! Not even with a looong wrench.
gjeffers 05-09-2005 06:21 PM
ORIGINAL: onewasp
ive taken mine apart a couple of times, it actually works great, use it, it wont hurt:D
