RCU Forums
-   Glow Engines (https://www.rcuniverse.com/forum/glow-engines-114/)
-   -   choke ssembly (https://www.rcuniverse.com/forum/glow-engines-114/3013802-choke-ssembly.html)
bako 05-26-2005 01:10 PM
choke ssembly
hi all.
people say here that choke plate on TT91fs affects on engine working. does it affect on magnum fs too?
thanks
wldcwbypilot 05-26-2005 01:35 PM
RE: choke ssembly
It interrupts the air flow so minutely. Wouldn't worry about it, take it off if your in temperate climate. You only need it in a very cold climate.
Flyboy Dave 05-26-2005 05:41 PM
RE: choke ssembly
I take them off all my four stroke engines. I prime the engine by putting
a finger over the exhaust tip, and flipping the prop through a few times. ;)
FBD. :D
w8ye 05-26-2005 06:05 PM
RE: choke ssembly
I've removed all the choke assemblies from my OS, Magnum/ASP, and old Saito engines. Some have been removed for several years. No problem
Enjoy
Jim
bako 05-27-2005 01:06 AM
RE: choke ssembly
i have removed it too, but engine wasn'tperforming well.
maby due to it was wery cold? :eek:
maby
Sport_Pilot 05-28-2005 10:24 PM
RE: choke ssembly
Keep in mind that on the TT .91 the choke has a venturi that is smaller than the carb bore and it improves the fuel draw. The others are the same or large bore as the carb. The only advantage they have other than the choke is that they act as a short velocity stack, which will reduce the amount of fuel mist blown out of the carb.
bako 05-29-2005 12:11 AM
RE: choke ssembly
so it means that fuel filter isn't wprts installing? it will change air flow in carb
William Robison 05-29-2005 12:41 AM
RE: choke ssembly
On all the Saito engines that have them, I keep the choke installed. It seals the base of the stack, if nothing else.
Yes, Bako, an air filter is well worth having.
Bill.
bako 05-29-2005 05:06 AM
RE: choke ssembly
sorry my english isn't as well in terminology. u mean I need to keep air filter far from my engine?
William Robison 05-29-2005 07:55 AM
RE: choke ssembly
Bako:
What you said was "Fuel" filter. I read it as "Air" filter. My fault, not yours.
But yes, if the air filter is about 3/4" (19 mm) from the carb spray bar it stays drier not getting as much fuel spray, and stays clean longer.
The short stack and the air filoter combined seem to eliminate all spray out the intake.
A fuel filter is also a good idea.
Bill.
