RCU Forums
-   Glow Engines (https://www.rcuniverse.com/forum/glow-engines-114/)
-   -   Piped Moki 2.10, Best prop? (https://www.rcuniverse.com/forum/glow-engines-114/3152117-piped-moki-2-10-best-prop.html)
marzo91 07-09-2005 10:17 PM
Like it says, which one is best? I've heard of the Moki Ultra. Is it still made? I'm thinking 20 x 8 or 20 x 10. Thanks for any reply.
JoeAirPort 07-10-2005 12:31 AM
RE: Piped Moki 2.10, Best prop?
Can't get Moki Ultra anymore. The Menz Ultra prop is the closest. The 20x10 is what they claim 25 pounds of thrust at 7600 RPM but I don't believe it. I use a Bambula 20x8 and it will turn low 7000's. What kind of flying is this for?
marzo91 07-10-2005 11:52 AM
Thanks for the reply. I'm going to use it on a OMP 79" profile Yak. So it's on a 3D machine. Should be under 12 pounds.
JoeAirPort 07-10-2005 03:43 PM
If it's 3D, I'd try the Bambula 20x8. It's got big paddles and pulls very strong. The prop is very light and makes for a quick transition. I would not use a 10 pitch because you want more diameter and less pitch. The 8 pitch is perfect. I use the Bambula props on my Moki 1.80 and 2.10. They are available here:
http://www.rcshowcase.com/html/acces...bulaprops.html
marc 540 07-11-2005 12:30 AM
I had the Moki 210 on a OMP 80" edge and at 12 lbs. it was awsome!!! I used Master Airscrew classic series 20x10 and 20x8 both with very good results. These props weigh about 5 oz. but have wide blades and are pretty inexpensive (about $15) Strait and level at about 1/4 throttle. hover about 1/2 throttle. Blast out of hover at 3/4 throttle. You will not need full throttle with this combo!! You will not be dissapointed.
Marc 540
marzo91 07-11-2005 05:35 AM
Marc 540, Thanks for both responses.
JoeAirPort 07-11-2005 08:34 AM
Bambula 20x8 only weighs 3 ounces. Normally props this size are around 5 ounces.
cu. in. 07-11-2005 11:08 AM
marzo91,
I have a Moki 2.10 and would like to try a tuned pipe on it. I am just looking for a small power boost that preserves throttle response. What pipe are you using and what has been your experience with it regarding power, tuning length, and throttle response?
Bruce
marzo91 07-11-2005 02:26 PM
I just got it a few days ago. I'm looking for tips too. If I get the hot set-up, I'll let you know.
cu. in. 07-11-2005 11:20 PM
Thanks marzo91.
Bruce
