4-stroke plug in 2-stroke engine?
how would a 2-stroke engine run with a 4-stroke plug in it? i have lots of these "miracle" plugs that say 2 and 4 stroke but i think they are just 4 stroke plugs. i have an os .46 ax and i just put one of those plugs in it and it will run fine but won't idle... is the plug too cold?
RE: 4-stroke plug in 2-stroke engine?
Just use an OS #8. I have used the OS F 4 stroke plug is some 2 strokes, but they were bigger 1.40 pattern engines, they seemed to like them better for some reason.
4-stroke plugs tend to be hotter than most 2-stroke plugs. Some larger - more than 20cc - engines often run better with 4-stroke plugs. When used in smaller - ie .40 size engines - with 10-15% nitro content fuels, the plug might not last long.
Safe Flying! |
i will change the plug as soon as i get the new ones in the mail from tower. could this plug be the cause of my idle troubles? because the engine ran perfectly before the last plug burned out
1 Attachment(s)
That plug is fine in a .46 engine, the first engine I ever used one in was an OS
.46....it made a crappy engine run real nice. They really work well in inverted applications too, because it has an extended tip, and does not drown out easily. ;) FBD. :D |
that is wonderful news! as soon as i finish building my ultra sport i'm taking the o.s. out of my girlfriend's trainer and putting it in the ultra sport inverted. guess i will stick with these longer plugs for that reason. she's getting the crappy tower hobbies .46 [sm=tongue.gif] now i'm trying to figure out my idle problem... i wish i was better with engines and knew how to fix these things myself! anyway, maybe y'all can help me on this one. i took out her trainer 2 days ago to fool around with and it wouldn't start, then realized the plug had burned out so i replaced it with the miracle plug... still wouldn't start. then i realized the bigger needle valve (don't know if it's low- or high-speed) was turned in all the way closed, so i turned it out to what i thought would be an acceptable setting.
still won't start. primed the engine with my finger over the muffler and flipped the prop a few times. it started! after it got running i leaned out the big needle valve to max rpms and then richened it a few clicks like i always do. it transitioned perfectly, revved up to normal rpm then when i brought the throttle back to idle, the engine ran at a higher-than-normal idle rpm and slowly lowered until it finally died, which occurred about 10 or 15 seconds after i brought it back to idle. i started it again and had the same problem over and over again, so i just came home if it isn't the glow plug, i can't figure it out. my best friend who i always go flying with is an engine master and would be able to just say ohhhhhhhh your flux capacitor whatchamacallit isn't tuned right and would fiddle around for a few seconds and it would run fine, but he has got a second job and i can't get together with him to help me. maybe you guys can thanks a whooole lot bill |
It sounds like your low speed needle is set too rich. Turn it in 1/8 turn at a time
till the idle improves. Once you find the sweet spot, the engine will run like a top. Be sure to reset the high speed. Peak the engine all the way to highest revs, then open the main needle until you hear the rpms drop a little. ;) FBD. :D |
ORIGINAL: Flyboy Dave It sounds like your low speed needle is set too rich. Turn it in 1/8 turn at a time till the idle improves. Once you find the sweet spot, the engine will run like a top. Be sure to reset the high speed. Peak the engine all the way to highest revs, then open the main needle until you hear the rpms drop a little. ;) FBD. :D I see a lot of your post and I agree all of them my question is about 2 cycle engine setting if is possible to have a post in the first page of this forum about how to set a 2 strokes engine: this IMO can help the new member how run correcly the 2 strokes before puting a lot of post about funny runing i think the new member start with a trainer w 2 strokes engine |
tigil....thank you for the kind words. [sm=thumbup.gif]
I have been planning a "how to" on setting-up and running a new engine for the guys that are starting out....I think it is a good idea also. ;) FBD. :D |
| All times are GMT -8. The time now is 07:45 AM. |
