RCU Forums
-   Glow Engines (https://www.rcuniverse.com/forum/glow-engines-114/)
-   -   Better .25 - .30 engine?? (https://www.rcuniverse.com/forum/glow-engines-114/3330523-better-25-30-engine.html)
exeter_acres 09-05-2005 11:37 AM
OK, if you have seen my other post, I have a tt .25 that is dying a slow death....
some point I need to replace it with an upgrade motor.. currently it is in a TT Lazy P-51, but would like to use it in other planes too
maybe combat spad, etc. etc.
Suggestions on a good .25 (or similar....larger is OK) sized engine that doesn't break the bank
should I step up to the .35 class of engine? WEbra .32? etc. etc.
William Robison 09-05-2005 11:54 AM
RE: Better .25 - .30 engine??
[b]EA:
Why not go "Cadillac" and get a small Saito? Or if you want to stay with two stroke the little Magnums are very good engines.
Bill.
Rupurt 09-05-2005 12:14 PM
Get a GMS 32 they are great, if the carb is ok, if it isn't it is a quick fix. Although it may be a little to much for that plane. Anyway for the money I think they are great, If you want to spend more go with Bills idea four strokes are brilliant.
pikebishop 09-05-2005 12:25 PM
tt 36 pro
RC-Captain 09-05-2005 12:50 PM
os .25 0r a little bigger, break in is a cinch.
piper_chuck 09-05-2005 02:39 PM
If you're actually going to do combat, you need to check the rules and buy an engine that fits within the specs. If not, there's lots of choices. Magnums aren't bad. The TT .36 Pro is nice. Webra .32 or .36 are also nice.
Dr1Driver 09-05-2005 03:35 PM
If .25 is your top limit, go with the Webra Speed .25. If you can go slightly larger, run the Webra Speed .32. They'll outrun anything else in the size class. Very user friendly, too.
Dr.1
exeter_acres 09-05-2005 05:14 PM
thanks all... as for combat.... it is just funfly combat with friends... no real classes so that is not an issue.....
Hmmm.... I've seen the .30 saito, but would that have the same as a .25 two stroke??
what to do, what to do....
is Chief about the only option for Webra?
