RCU Forums
-   Glow Engines (https://www.rcuniverse.com/forum/glow-engines-114/)
-   -   Prop Question!? (https://www.rcuniverse.com/forum/glow-engines-114/3426438-prop-question.html)
ICE_MAN 10-05-2005 08:30 PM
Prop Question!?
Anyone tried a Menz(or other) 18X8 on a Super Tigre G2300?
airbornrc 10-06-2005 12:27 PM
RE: Prop Question!?
Mine liked a Mejlik 16/8. it was on a IMAC type plane. 18/8 was too much.
ICE_MAN 10-06-2005 07:50 PM
RE: Prop Question!?
I had a Mej. 18X6 on it... not to much by anymeans.. It turns 9200... Do you think a 2" increase in pitch will be too much
daveopam 10-08-2005 10:20 AM
RE: Prop Question!?
I run a 18x8 Zinger on my 3250. It's 1.99cu and the 2600 is a 1.40cu. I think your over proping it a bit.
David
ICE_MAN 10-08-2005 11:13 AM
RE: Prop Question!?
Maybe I'll stick with the 18X6 then. The 2300 turns it at 9200 RPM with a good trail of smoke. No problem turning it.
STG 10-08-2005 11:45 AM
RE: Prop Question!?
Ice man have you ever herd of SKOREPA" brand wooden props? Dick Hanson likes them. I am going to try a few.
http://www.escomposites.com/wooden_props.htm
What muffler are you using and are you running a pump? Any problems getting the carb to meter an instant spool? I am debating on motors--was thinking about the OS1.6FX but the ST2300 is so much less. Are you running one of the newer ST2300's?
