help !!
hi,
i have a mvvs 150 engine with 45 deg exit. when i put it on the plane the exit of the tune pipe is lower then the fire wall of the plane so i heat up the adaptor of the tune and bend it a little. when i started the engine the adaptor break to 2 pcs and then i fix it and its broke again in another place. i think that the heat destroied the adapter strength becu its alominiom. does anybody have an idea for me? thanks nir |
RE: help !!
It should have been post heated in an oven to stress relieve it.
RE: help !!
1 Attachment(s)
Hi Nir,
Please enter the [link=http://www.krumscheid-metallwaren.de/neu/shop.php?lang=EN]Krumschied web site[/link] and press the accessories tab. I am sure you will find a suitable solution to your problem. Among them are flexible pipes, like you were interested in. Good luck. Take a look at the other things in that site too. |
RE: help !!
thanks , i sent them a mail.
how can i put a picture here? |
| All times are GMT -8. The time now is 08:42 AM. |
