RCU Forums
-   Glow Engines (https://www.rcuniverse.com/forum/glow-engines-114/)
-   -   GP Super Skybolt engine? (https://www.rcuniverse.com/forum/glow-engines-114/359293-gp-super-skybolt-engine.html)
hiddenicon 11-11-2002 04:43 AM
I just purchased a GP Super Skybolt. Looks like an awesome flyer. I'm still pondering on what engine I want to put into it. I never had a 4 stroke before and I'm leaning more towards a 4 for this plane. Anyone have any experience with this plane and 4 strokes? I was thinking either an OS 1.2 or a Saito .91. Any suggestions?
fiery 11-11-2002 08:30 AM
GP Super Skybolt
A Saito 150 ...
As the advert in RCM used to say, Va Va Voom !
hiddenicon 11-11-2002 03:35 PM
1.5 won't be too much?
BJE 11-11-2002 04:33 PM
Never can have enough
I put a Saito 1.80 in mine. It will sustain vertical at 1/2 throttle and really move vertical at full! Lots of fun, but definately overpowered. FYI, I still had to add a bit of noseweight in mine, so that's not a factor.
hiddenicon 11-11-2002 04:36 PM
I'm getting a lot of feedback of people using Saito 120 and 180's. How was the fitting of the 180? any customization on the cowl and whatnot?
SilverEagle2 11-11-2002 04:59 PM
180
180is 2mm taller and mounts in the same dimensions as the 120. I was going to us a .91 in mine since I have it laying around. I hope to not have the tail heavy problems this plane seems to have when I build though.
Cheers
Mendes 11-11-2002 08:08 PM
Aren't you guys having problems with ground clearance? I was using a 15x6 when I had a 1.20 four stroke in mine and really had to get a nice three point landing so that the prop wouldn't touch. Now I am using a .90 2 stroke, not as powerfull but still a great match for this plane and the 14 inch prop never touches the ground.
fiery 11-12-2002 03:50 AM
Clearance
three bladers are the answer ... you don't loose as much performance as some would have you believe, and they look real cool.
Ali spinners for 3 bladers at a reasonable price can be found at Cermark.
3 blade props are expensive though ...
SMALLFLY- 11-12-2002 01:28 PM
I have a saito 120 in mine swinging a 15-8. Plenty of engine for this plane
hiddenicon 11-12-2002 06:11 PM
I'm really leaning toward the saito 120 now. Did you need to use any spacers?
SMALLFLY- 11-12-2002 07:09 PM
No. It balanced perfect with battery in plan location using the GP adjustable 60-120 mount. A few flying tips. NEVER try to stretch a glide in. It will drop pretty quickly due to drag on landing, plan for it. It will not tip stall but just drops like a brick when it stalls. Try an inverted flat spin it does a great one. Oh a 14-7 3 blade MA also works pretty well with the 120 for a little more ground clearance
hiddenicon 11-12-2002 07:10 PM
Done. That convinced me right there.
Devo 11-16-2002 09:46 AM
I recently finished a Skybolt using the Saito 120. Extremely smooth flier since first flight. Nothing better than a four stroke in a biplane. Couldn't be happier other than the prop clearance. Started with a 15-8. After that flight I switched to a 14-10. Flies excellent and faster than I expected. I've experienced the stall mentioned by smallfry, it's not a big concern, but something to be aware of. I used a Dubro soft mount with none of the spacers provided in the kit. I also had to add weight to the nose. Enjoy.
SilverEagle2 11-17-2002 03:49 PM
What about...
An RCS 140. No need to add nose weight and you can run cheap and powerfull gas!!
Just a thought.
Cheers
Boomstriker 11-18-2002 03:14 PM
Skybolt
1 Attachment(s)
I've got a pumped TT120 w/ 15x8 & Bisson pitts
Tanks on CG
Balanced perfectly
Kirk
